Thread Tools |
#1 |
Just another nobody
Aliasing and Filtering explained
http://www.bit-tech.net/hardware/200...ltering/1.html
I'm pretty pleased with how this turned out. It's simple, and possibly a little simplistic, but I think it gets over the ideas behind these techniques without burying you in jargon. Thoughts?
#2 |
is watching you...
Great job, Wil. Enough detail to understand what's going on without being just too complicated for the mortal man to comprehend (Sorry Tim
) - I'll definitely be showing this to people rather than trying to explain myself
__________________
Water/144@2.9/Neo2/GSkill/6800 <@Cainer> eat my pwn, nerds!
#3 |
obey the fist!!
Nice, but am I supposed to be able to see something in this shot?
![]() It's a bit on the dark side!
__________________
Big, half-finished, parts hanging out computer ATCS 210; MSI mATX; AMD 4000+; HD4770; 3GB DDR400; 2x120GB + 2x1TB; 19" HANNS-G |
#4 |
What's a Dremel?
Pretty good stuff
The basics explained without going too overboard. A good read while I have a tea-break, cheers!
#5 | |
I Mod, Therefore I Own
![]() also those comparison screenies would probably work better if they were a bit bigger, had to zoom in to see the jaggies and nojaggies properly
#6 |
Mudkips.
Excellent Read, it’s certainly helped me understand AA an AF better.
Thought the comparison screenshots where fine though, perhaps you guys need to tweak your monitor settings
__________________
Network Engineering & Security, CCNA, ITIL (F). GM IT Security Analyst
| Shadow_101 |
| View Public Profile |
| Find More Posts by Shadow_101 |
#7 |
The other Brett.
Moderator
Very good read, one of the best articles yet.
Explained everything in a way I could understand.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home" www.yodasarmpit.com clickr my flickr |
#8 |
Don't panic!
Very good article, i don't agree about the pictures though - the bricks example worked really well for me!
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#9 |
oh ok, i can see the bricks on this monitor, secondary monitor is set too dark
#10 |
What's a Dremel?
Hmmp.. JPG? Horrible quality... why dont you use png or gif.. much smaller and better quality with pic that have only a few colors in it.
![]() Good job.
__________________
#11 | |
Supermodder
Good article, BTW... |
| ralph.pickering |
| Find More Posts by ralph.pickering |
#12 |
Lazy Lurker
I think most of us can agree that a brighter spot would have made a better example in the dark photo. But, either way, excellent article - you've made AA and AF easy to understand
__________________
Technology Schmecnology Last edited by RotoSequence; 4th Jul 2005 at 17:49. |
| RotoSequence |
| Find More Posts by RotoSequence |
#13 |
bwarp
Moderator
Fantastic article
__________________
This post is non-negotiable. All terms and conditions apply. Arguing on the internet is like competing in the special Olympics. Even if you win you're still a retard. |
#14 | |
Pewlius Caesar
bit-tech Staff
__________________
#15 | |
Lazy Lurker
__________________
Technology Schmecnology |
| RotoSequence |
#16 | |
Richard Swinburne
bit-tech Staff
#17 | |
Ecky thump
Moderator
![]() Perhaps links to some freeware aids should be added to the article? I understood all that and my head doesn't hurt too much,
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. |
#18 |
Minimodder
I'm pretty sure rotated grid 4xAA is _not_ rotated by 45 degrees... I think something more like 26.565 degrees would work better as then the four points have X and Y-ordinates regularly spaced along each axis, so for near-vertical and horizontal lines (where aliasing is arguably worst) it is of the best quality you can do.
OTOH NVidia and ATI might have decided to use 45 degrees for some perverse reason I am too stupid to comprehend... Or maybe I should patent the angle "26.565 degrees" and sell it to them ![]() [edit] Found an in depth article on this http://www.3dcenter.org/artikel/mult...g/index6_e.php with some pictures: ![]()
#19 |
What's a Dremel?
An example of a difference between ATI and Nvidia is the fact that ATI implement gamma-corrected AA on all their 9700+ cards, a technique which samples alpha particles inside triangles as well as gamma particles on the outside of triangles. This is only implemented by Nvidia on the 7800 GTX.
Gamma particles? Is this some sort of inside joke? I think you have perhaps simplified too much ... Multisampling does not require samples to be shared between pixels. Its an approach some vendors use to try to get better image quality. It's misleading to say mipmaps are lower-quality distance textures. They are multi-resolution texture image sets (pyramids) used to approximately match the variable resolutions needed for different object scalings by choosing the closest matching (or pair of matching) images. You probably meant that, but it's not what the article is saying ... |
#20 |
Hypermodder
very nice article. explains without confusing. gives enough information to inform, without being too technical, and gives the reader many avenues to explore if they want to know more.
| Thread Tools | |
