RSS
Old 15th Jul 2005, 11:05   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
Shuttle SD31P
http://www.bit-tech.net/hardware/200...e_sd31p/1.html
WilHarris is offline   Reply With Quote
Old 15th Jul 2005, 14:37   #2
dire_wolf
Revelation Machine
dire_wolf's Avatar
dire_wolf is on a distinguished road
Have I been playing far too much HL2 or does that look like an evil western digital brain crab ?
__________________
Marching Into History, Marching Into War, Marching Into History To Function As A Whore
"Don't Fear Citizens! TAD KNOWS HIS RAID!"
dire_wolf is offline   Reply With Quote
Old 15th Jul 2005, 14:47   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
haha, now you mention it, yes it does
Tim S is offline   Reply With Quote
Old 15th Jul 2005, 17:09   #4
preatorian
Multimodder
preatorian is on a distinguished road
lol dire_wolf :P
anyway, what's the price-tag on this baby ?
__________________
left hand : buy and spend
right hand : smash to pieces and rebuild it better
preatorian is offline   Reply With Quote
Old 15th Jul 2005, 23:13   #6
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Hehe...braincrabs got 'im. That's why he couldn't get down that far in the article.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 21st Jul 2005, 16:17   #7
LordGuyver
What's a Dremel?
LordGuyver is on a distinguished road
I have just built my SD31P and I have had a few problems and a few questions that I would like reviewed.
My Build:
Intel Pentium D 830 3.0 gHz
2 GB PQI DDR2 667 Ram
Gigabyte GeForce 7800GTX
2 x Hitachi SATA300 250GB Hard Drives in Raid 0 Array
Sony DVD-RW w/Dual Layer
Floppy
Windows XP x64
My Problems:
1. During installation of Windows XP x64 the system would BSOD (Blue Screen Of Death) while windows was attempting to install device drivers. After some testing I found that the Raid Driver provided by Shuttle was causing the BSOD. I tested this by elimating the use of RAID and reverted to single drive. The installation was successful with no RAID.
2. When using CPU-Z to verify my installation I found that my TRAS is not reporting correctly.
3. I was able, with some careful shuffling install my new GeForce 7800GTX video card into the case with the fan duct. It is very tight. The duct sits against the PCB and does touch the little capacitor on the end of the card.
4. After installing the updated raid controller management application I saw that my two RAID 0 drives were running at SATA 150 and not SATA 300. I have tried to set in BIOS the RAID Drive Port Speed to SATA II, but that didn’t fix the problem.
My Solutions:
1. I rebuilt the RAID 0 array, and during installation used an Intel RAID Driver for this chipset which I downloaded from Intel’s website. The problem BSOD was gone.
2. No Solution.
3. No Solution.
4. No Solution.
My Questions:
1. I am hoping that shuttle will fix this issue by releasing a newer version of the BIOS? I wish they would put some drivers, support, etc on the website for this model?
2. Same as above.
3. They need to release a newer version of the fan duct so it will accommodate the GeForce 7800GTX cards better? They should make this free to the bleeding edge crowd!
4. I would think this can be dealt with through a BIOS update?
Conclusion:
Overall I am very pleased with the rig. I was after something small and portable (LAN Party Trips) which could play the big games like BF2, H2, and Swat 4. Of course I needed it to do some other things like pay the bills too.
Thanks,
Lord Guyver
LordGuyver is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
