Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 10th Jun 2004, 16:16   #41
Jesterjedi
Multimodder
Jesterjedi's Avatar
Jesterjedi has yet to learn the way of the Dremel
i feel sorry for the mobo...
__________________
Design, Build, Enjoy, Mod some more...
Its all in a days work, if i can be arsed to get out of bed and do it.
Jesterjedi is offline   Reply With Quote
Old 10th Jun 2004, 16:47   #42
bleecher
Supermodder
bleecher's Avatar
bleecher has yet to learn the way of the Dremel
what!??!?!
Hard Drives do have air holes! -which i discovered doing a submerge system.
bleecher is offline   Reply With Quote
Old 10th Jun 2004, 16:56   #43
hacker 8991
Hypermodder
hacker 8991 has yet to learn the way of the Dremel
JesterJeid: Why?
- tf
hacker 8991 is offline   Reply With Quote
Old 10th Jun 2004, 22:23   #44
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysis
I'll be sure to post some pics, but It might be a week or two, since I dont have a digi cam right now
metarinka is offline   Reply With Quote
Old 10th Jun 2004, 22:47   #45
VirtualJedi
Multimodder
VirtualJedi's Avatar
VirtualJedi has yet to learn the way of the Dremel
Still hoping to see the end result of this.
__________________
Why use a Dremel, when you have a lightsaber...
VirtualJedi is offline   Reply With Quote
Old 10th Jun 2004, 23:28   #46
L2wis
Hypermodder
L2wis's Avatar
L2wis has yet to learn the way of the DremelL2wis has yet to learn the way of the Dremel
nice one! Yeh i can't wait to see how this one is going to end. Don't HDDs have the air hole so the presure can equlise(sp?)?
__________________
Lewis.
www.madebylewis.com
L2wis is offline   Reply With Quote
Old 11th Jun 2004, 14:08   #47
Jedi
Supermodder
Jedi's Avatar
My thoughts aswell atm but i'll wait to see how the end results is :P
__________________
Computay: Abit NF7-S Rev2 | TbredB 2100 AIUHB @ 2316mhz | 9800Pro [R360 with 9800xt pcb] | 512mb Generic pc2100 178@2.5-3-3-6
(Future) Server: Epox 8k7a+ (bulging caps need fixing :S) | Mobile Duron 1GHz | Asus GF3ti200 @ 255/520MHz
[atrack]Jedi[/atrack]
Old 11th Jun 2004, 16:02   #48
danmagicman7
Modder
danmagicman7 has yet to learn the way of the Dremel
Uhm, the guy probably painted over the little hole which has a small air filter piece in it. Now you HD's arn't going to work...for long...
He painted the freeking video card heatsink...that is definately going to have an effect.
Also, the paint may melt or even burn, the paint is just insulating the motherboard and bathing it in its own heat.
danmagicman7 is offline   Reply With Quote
Old 11th Jun 2004, 16:10   #49
hacker 8991
Hypermodder
Ooo great first post. Diss my work.
Did you even read the thread? The only parts that gets hot are those rings with coils.
Yeah, and in the original thread by lamcdonald, he painted the CPU heatsink. No negative effects.
HDDs are airtight and manufactured in clean rooms. If there is an air hole in one, it does not touch the platters, which means that it would be impossible to get spraypaint on the platters.
Do some research before you go a-flaming me.
Happy first post
- tf
Old 11th Jun 2004, 16:18   #50
danmagicman7
Modder
It clogs the filter, which means air can no longer go in/out of the HD.
I'm not trying to flame i am just thinking out loud.
I'm just saying that a large layer of paint isnt necessarily...well good for your computer. Paint insulates heat...you just have to be careful how much you use.
Old 11th Jun 2004, 16:55   #51
r3Q
Supermodder
r3Q's Avatar
r3Q has yet to learn the way of the Dremel
hmm. imagine why he TESTED IT BEFORE ON A OLD MOBO. jesus.
basically, if it were me, i would prolly use uv reactive- and do a speckle paint job.. less paint, less heat and i would most likely take the heatsinks off and not get paint on those. i think it kinda looks messy.
but i wouldnt paint over the stuff like capicators the mosfets or the chips.. just the PCB and resistors and the small stuff... i would do alot more taping than he did (then i would get some UV reactive pens and paint over that)
i think it would look alot neater this way. i would prolly just order some green or white heat spreaders (and not paint over the ram CHIPS on the ram dimms... that just dosnt look fun to me =\
theres a few things that id do different if i had the time, but he likes it, and it works for him. so let him do what he likes aight man?
i think you got balls man. as for me, all my warranties are gone anyway, so i might get some UV paint and try it myself =)
__________________
-r3Q
r3Q is offline   Reply With Quote
Old 11th Jun 2004, 17:04   #52
autocan
What's a Dremel?
autocan has yet to learn the way of the Dremel
autocan is offline   Reply With Quote
Old 11th Jun 2004, 17:25   #53
hacker 8991
Hypermodder
Originally Posted by autocan
Ooo so constructive. Are people still angry that I can apply paint to electronics, or are they just sad because they cannot?
Please, if you are going to bash me, at least tell me why. I am trying to write a guide here. You do not have to follow the guide.
- tf
Old 11th Jun 2004, 17:29   #54
danmagicman7
Modder
Im just pointing out the setbacks, what i do best
I'm not saying i don't like his mod, i think its cool, just i don't think its great for electronics.
Where did i say what he did was bad? No where. I just said it may cause problems.
P.S. I wouldn't paint the RAM, its too expencive and gets hot! Use some cover on it.
Old 11th Jun 2004, 17:58   #55
hacker 8991
Hypermodder
Yet again, you failed to do any research on the subject before posting. Heat spreaders on RAM, more often than not, trap air underneath them and cause the RAM to overheat. A thin cover of spray paint will have little effect on RAM, which is not the hottest part of the system.
For those of you that are still waiting for the conclusion to part 2, just wait. The weather has finally cleared up, and I can finish the guide.
- tf
Old 11th Jun 2004, 18:36   #56
danmagicman7
Modder
- tf
Why do companies install them then?
Old 11th Jun 2004, 19:29   #57
hacker 8991
Hypermodder
Because they look cool, and they can put more labels on them.
- tf
Old 11th Jun 2004, 20:59   #58
Gecko
Supermodder
Gecko's Avatar
Gecko has yet to learn the way of the Dremel
I feel i ahve to say this, but that gigabyte motherboard looked amazing before, how do i know? becuase i;ve got one, i would never ever ever think about painting it. It looks horrible when its been painted.
__________________
40D :: Sigma 10-20 :: Sigma 24-70 :: Sigma 30mm F/1.4 :: Canon 70-200 L :: Manfrotto 190X Pro B :: Manfrotto 484RC2 :: Lowprowe Fastpack 250
Macbook Core 2 :: 3GB :: 250GB
Gecko is offline   Reply With Quote
Old 11th Jun 2004, 21:45   #59
danmagicman7
Modder
- tf
Yea, they do look cool
Gecko...are you the gecko from the alienware.com forums?
Old 11th Jun 2004, 22:47   #60
L2wis
Hypermodder
L2wis's Avatar
Well i like my mobo the colour is it too (pc chips red ). I thought of a solution if ur HDD has a hole!
Plug the hole with a pencil lead (still attached to the pencil!) hold the pencil vertical and spray away. When done spraying remove the pencil! That must be as easy as it gets! Remember KISS! (probably a general term but i learnt that from electronics... for those unsure what that means: Keep It Simple Stupid!)
__________________
Lewis.
www.madebylewis.com
Reply
Tags
guide
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
