Thread Tools |
#1 |
Just another nobody
ABIT AW8-MAX & Gigabyte GA-81955X
#2 |
Supermodder
i liked 'low quality benchmarks', because not everyone matter of details.
strange doom3 between 640x480 LQ and 1280x1024 HQ changes only 20fps
__________________
Teh Case coming soon............maybe (well...by now it's just a lian li a05b )
#3 |
Pewlius Caesar
bit-tech Staff
It just shows up the difference between Intel and AMD-based CPU's. AMD are very strong in low-detail CPU-intensive gaming benchmarks.
__________________
#4 |
Brett Thomas
Great job on the article, Bindi! Truly enjoyable read.
I keep looking at these Intel dual cores, because they're so much cheaper than the AMD. Dumb question, though...do each one of the cores then come with hyperthreading?
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#5 |
Pewlius Caesar
bit-tech Staff
Only the Pentium Extreme Edition 840 has Hyperthreading (four logical cores), the Pentium D's only have two 'physical' cores. No Hyperthreading support.
__________________
#6 |
Brett Thomas
Hmmm...damn. That makes for one expensive arsed piece of hardware, since it's $1000.
__________________
#7 |
When did I get a custom title!?!
also with a 120w prescot water cooling is almost mandatory :P
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#8 | |
Richard Swinburne
bit-tech Staff
#9 |
Pewlius Caesar
bit-tech Staff
stock intel reference air cooling at that, too.
__________________
#10 |
Lazy Lurker
Technically AMD also released the X2 3800+ recently, which competes rather well with the 830s; if your budget calls for an 820 though, its probably the better option. You sure that 3.73 EE isnt cherry picked?
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#11 |
What's a Dremel?
As for free-be's in the box, while the specs were mentioned in the review, it was never mentioned that the AW8-Max has SPDIF IN and OUT, while Gigabyte just has the SPDIF OUT. That's a free-be in the AW8 column, if you ask me. I haven't used the AW-8, but if there is reasonable software support for the IN, it could be handy outside of gaming.
| JonComputes |
| Find More Posts by JonComputes |
#12 |
Richard Swinburne
bit-tech Staff
The AW8 has optical S/PDIF in and out on the SoundMAX daughter board. It's not really a free-be so to speak, imo.
__________________
| Thread Tools | |
