Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd Aug 2005, 17:38   #1
rectro
What's a Dremel?
rectro has yet to learn the way of the Dremel
lcd HD44780 controling brightnes and contrast how?
I got a lcd HD44780 20x4 display but no software as of yet can enable me to change the brightness/contrast as its way too bright.
If I powered it via a fan controler bus would this damage it?
__________________
Abit AN7 , XP2800+ at 2400mhz, 120gig HD, 1gig PC3200 memory, Audigy Platinum, ATI 9800XT, WC with Danger Den TDX, DD M4 chip set , DD M4 GPU using liquid XP+ with dual heatcore + shrowd.
rectro is offline   Reply With Quote
Old 2nd Aug 2005, 17:48   #2
SteveyG
Electromodder
SteveyG's Avatar
SteveyG has yet to learn the way of the DremelSteveyG has yet to learn the way of the Dremel
What are you currently using to limit current to the backlight?
Fan controllers are usually for 12V fans, so you'd need to adjust your current limiting resistor to set the maximum current to ~300mA when connected to 12V. Once you've done that then yes you could use your fan controller to control the backlight (not the LCD power though!)
SteveyG is offline   Reply With Quote
Old 2nd Aug 2005, 18:02   #3
2800@2.5ghz
Multimodder
2800@2.5ghz has yet to learn the way of the Dremel
see the wiring diagram on LCD smartie, thats what i used, jsut put a 10k variable resistor in the circuit
2800@2.5ghz is offline   Reply With Quote
Old 2nd Aug 2005, 19:33   #4
rectro
What's a Dremel?
so you cant do it with software then?
__________________
Old 2nd Aug 2005, 19:36   #5
2800@2.5ghz
Multimodder
nope dont think so
Old 2nd Aug 2005, 19:38   #6
coorz
Miffed
coorz's Avatar
coorz has yet to learn the way of the Dremel
Standard HD44780 wiring scheme has variable resistor (potmeters) for adjusting brightness and contrast. Also some apps can do software brightness control, i believe (not sure) LCDHype, Smartie or another one....
__________________
MK3 | L | D300
coorz is offline   Reply With Quote
Old 2nd Aug 2005, 20:10   #7
rectro
What's a Dremel?
LCDhype looks like it may controll contrast but the manual is not english and cant for the hell of me work out what to do with it?
__________________
Old 2nd Aug 2005, 20:20   #8
rectro
What's a Dremel?
Would you be so kind you direct me to this diagram that shows what I need to mod to add pots the enable contrast and brightness?
__________________
Old 29th Jan 2009, 19:55   #9
M.777
What's a Dremel?
M.777 has yet to learn the way of the Dremel
Sir SSteveyGteveyG
I am new ……..
The Schemetic for the LED clock I made today
is not visible. I am unbale to complete the project. Can you please help to get the complete information
Thanks.
M.777 is offline   Reply With Quote
Old 29th Jan 2009, 19:58   #10
M.777
What's a Dremel?
Sir SSteveyGteveyG
I am new ……..
Thanks.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
