#1 |
Geoff Richards
Moderator
Shuttle SN26P with SLI
#2 |
Ultramodder
Nice one
![]() Very nice little box o' tricks, were you not tempted to hack it up to get the extra room for the GTX cards? Tis impressive what you get in a box that big nowadays, still wouldnt buy one as my 'main' pc though.
__________________
++ASUS SLI Premium | X2 3800 @ 2.6ghz | XP-120 | 2GB Mushkin | 8800 GT | XFI Music | Seagate 320GB \ Samsung F1 1TB | 520W Corsair HX | 23" Dell S2309W ++
++Zotac 9300 Mini ITX | Intel E5200 | Scythe Shuriken | 2GB Corsair | 8600 GTS (Passive) | WD Black 2.5" 320GB \ Samsung F2 Eco 1TB | Corsair VX 450W | 42" Panasonic Viera++ ++Canon 400D | Sigma 17-70mm f/2.8-4.5 | Canon 75-300mm f/4.0-5.6 | Sandisk Extreme III 4GB++My Ebay++ |
#3 |
Group 7 error
mmmmmm, very tasty. Although i must admit that my very first thought when i looked at the review was "i wonder if the cooling system would fit a 7800." and you answered the question all right, but no PICs? or is that being greedy
__________________
http://www.ctrlaltdel-online.com 100% Brainless] |
#4 | |
Geoff Richards
Moderator
LAGMonkey: Pics of 7800 are on Page 4 mate: http://www.bit-tech.net/hardware/200...26p_sli/4.html
7800 GT that is - the GTX doesn't fit, as noted. Quote:
As mentioned in the review, this is a press preview sample, or a "nearly final engineering sample" if you like. Shuttle are aware of a few issues, and are working hard on fixing them all, and one of which is GeForce 7 support. You have to remember that the GeForce 7 series wasn't even on the radar when work begun on this design, so the switch from 6800 to 7800 has put Shuttle in a bit of a bind. Since the full model isn't due out until Q4, it is possible that the 6800 support will be dropped completely in favour of 7800s. But that is just my conjecture |
#5 | |
Modder
__________________
no, your face. |
#6 | |
Ultramodder
__________________
#7 | |
Geoff Richards
Moderator
Fixed.
#8 |
Hypermodder
damn thats a sexy box.
#9 |
Group 7 error
Sorry Pope, i should have said that i wouldnt have minded seeing 7800 cards WITH the shuttle cooling system installed on them and not stock cooling.
But thanks for the great review anyway
__________________
#10 |
Geoff Richards
Moderator
Ah ok. Sorry - we didn't have time for that, and suspecting there will be an official Shuttle 7800 version, we didn't want to kill our lovely 7800s trying. There is nothing wrong with the theory of fitting them, but you can't just go bending heatpipes willy nilly to fit your purposes - they won't survive that treatment.
#11 |
Bored
Well i hope if shuttle do decide that 7800 support is a good idea, that they then dont drop the 6800's because by then id actually be able to afford the 6800's
__________________
>[DFI LAN-PArty UT NF4 Ultra-D]-[Athlon64 3200+ Winchester]-[1Gb Corsair pc3200]-[Vapochill Micro]-[Powercolor ATI Radeon X800XL 256Mb]-[Chieftec DX-01-YL With 6 Fans]< Pug- "The spirit of modding is unleashing your creativity in the pursuit of individuality." Current Project: Unnamed Chieftec Dragon Mod |
#12 |
Supermodder
Any update when this is coming out in the UK and if it will be 7800 or 6800?
I have about 3 mates dying to buy one!!! Ive heard if there is one thing Shuttle are v poor at its being on time with releases. Mickey |
#13 |
Pewlius Caesar
bit-tech Staff
There is no confirmed shipping date for this product - they are back to the drawing board addressing some of the issues that we highlighted with this particular system and we suspect that there will be another sample heading our way in Q4 some time.
__________________
#14 |
Supermodder
Im guessing next year then???
#15 |
Supermodder
HOw many hdds can be fitted in it? Could i get two raptors and a date drive in there?
Nikumba |
#16 |
Pewlius Caesar
bit-tech Staff
IIRC, there is only room for two if you have the heatpipe cooling solution installed.
__________________
#17 |
What's a Dremel?
hi all,
the shuttle europe site says that the SN26P doesnt use the heatpipes anymore with 7 series cards. instead uses stock cooling of the cards. how is that possible? one fan is going to be tightly stuck between the cards. where will the air come from!!!??? any one tested this config and GPU temp yet? |
| mememe&myshuttle |
| View Public Profile |
| Find More Posts by mememe&myshuttle |
#18 |
Geoff Richards
Moderator
welcome to the forums mememe&myshuttle.
I'll track down the page you're referring to and see what Shuttle have to say. |
#19 |
What's a Dremel?
Any updates on this? I'm interested in a SFF SLI computer. Have the issues been resolved?
Is the dual graphics card option only available with the factory installed heat pipes or will 7800GTX work fine now? Last edited by JAG Wolfe; 1st Jul 2006 at 22:08. |
#20 |
conflagration.
Sweetness, i like a small computer with a lot of power... be a bit of a heater though, not?
| Thread Tools | |
