RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Aug 2005, 14:31   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AOpen's i915GMm-HFS Pentium M motherboard
http://www.bit-tech.net/hardware/200...gmm-hfs/1.html
Tim S is offline   Reply With Quote
Old 23rd Aug 2005, 15:24   #2
Deep-Blue
Part-time Overclocker
Deep-Blue's Avatar
Deep-Blue is on a distinguished road
Personally i like the idea of a Pentium M based rig. I could go an purchase a passivly cooled 6600, a Samsung silent hard disk, and nice Asus silent optical drive, and a SMALL matx chassis, and have a very quiet, very powerful, and yet very small machine!
If you could fill the 2x DDR2 slots with 2x 1Gb 533Mhz DDR2 sticks, and a low profile GeForce 6200 Turbocache low profile card in the 16x slot, you could use even less power, still have decent gaming, and have a brilliant all rounder.
All that is really needed, is for a few more mobo manufacturers to produce boards (competition is goooood), and for Intel to reduce the price of Pentium M to a reasonable price.
Once thing i did notice though. Nothing was mentioned about Celeron M support. Do we know if it will take a CM?
Edit: ebuyer.co.uk has Celeron M starting at £104 inc VAT. If the board supports Celeron M, i may just have to look into this gear for a small linux box.
Deep Blue
__________________
[iMac C2D 2.4Ghz - 4Gb Memory 667Mhz - 320Gb HDD - 10.5]
[Lenovo M55p Tower - Core2Duo E6300 1.83Ghz - 6GB DDR2 6400 - GeForce 7800GTX]
Deep-Blue is offline   Reply With Quote
Old 23rd Aug 2005, 15:30   #3
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
The_Pope is on a distinguished road
Yep - sounds like you're the kind of enthusiast that AOpen are targeting with this board
The_Pope is offline   Reply With Quote
Old 23rd Aug 2005, 15:35   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
6200 decent gaming?? There's little point of DDR2 gig sticks, when you could buy two gig sticks of PC3200 and they would run at low latency DDR333 with virtually no performance loss and you'd save money too.
It supports any Pentium M, inc Celeron.
The P-Ms are damn nice CPUs, if you wanna only game or only use it as a media centre. As a core PC i'd go P4 everytime (if you are an Intel fan).
Bindibadgi is online now   Reply With Quote
Old 23rd Aug 2005, 15:38   #5
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
I personally prefer "fast enough" and as quiet as possible. Pentium M is perfect for that. What exactly do either of you need 2GB of RAM for btw? If you're gaming, then Battlefield 2 and that's almost it, but any mention of a 6200 kills that idea.
2 x 512MB is plenty for Media Center (note the correct spelling Bindi!)
Old 23rd Aug 2005, 15:59   #6
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Cheeky! I say it's Windows Media Center Edition (that being the spelling of the trademarked software name, effectively a proper noun), but referring to an HCPC (Home Cinema PC - who has a theatre in their house? That's just silly, unless you want a private performance of Macbeth) I would call it a media centre (that being the correct way to spell the word!)
mclean007 is online now   Reply With Quote
Old 23rd Aug 2005, 15:59   #7
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
You and you're frikkin Americanisms.
Centre is spelt "RE" in proper oxford-english :P If we're talking trade marks, sure it's the other way around but you'll be walking over my cold dead body before i willingly do it though. Along with spelling sulphur with an "f".
If you're running a Turbo Cache then you want extra ram, but seeing as it's single channel DDR anyway you might as well buy a gig and a 512meg stick.
Noise: depends what you're used to really; you cant put a huge heatsink on the Pentium Ms which is unfortunate but you can run them virtually passively!
Old 23rd Aug 2005, 16:19   #8
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Media Center PC's are all about silence - I'd be pissed off if there was anything remotely noisy in my MCPC - Wil's has a fan that moves, and that'd annoy me sufficiently.
I'm thinking of building one at some point - I'll be passively watercooling it I think. I may even go so far as to get an i-RAM and then have my hard drive array in another room.
Old 23rd Aug 2005, 16:24   #9
mclean007
Officious Bystander
mclean007's Avatar
Zalman Reserator?
Extreme silence bigz! How about running a Linux box with MythTV front-end and booting it over ethernet, with your disk array on a back-end server in a different room? Saves on the i-RAM, plus it's pretty cool (to geeks anyway!)
Old 23rd Aug 2005, 16:34   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I've got a lot of watercooling kit already lined up, but I might consider trying to use a reserator tank in the loop rather than a more conventional radiator. The only problem is that the pump can rattle in there, so that would have to be replaced with something else.
Old 23rd Aug 2005, 16:41   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
You'd have to build a custom hold down though, good luck on that :P
Old 23rd Aug 2005, 16:43   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I wasn't planning on using this board...
Old 23rd Aug 2005, 16:46   #13
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Most pentium Ms have a custom hold down though, unless you're going Asus P4P/C + CT479.
Old 23rd Aug 2005, 16:52   #14
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
mclean007 is spot on. Media Center is software for a media centre
For the sake of clarity, I use HTPC if I want to talk about the generic group, otherwise specifically Media Center if referring to Microsoft Windows MCE.
Old 23rd Aug 2005, 17:08   #15
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
great idea but why the custom heatsink! this would work great with a heatsink like the xp-120 running passivly.
Infact I would be ordering one now if ti wasn't for the stupid heatsink...
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 23rd Aug 2005, 17:39   #16
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Fair enough. I just used media centre as a generic term and Windows Media Center as the trademark then.
There's very little space on the board, and so having a full P4 mount would take up too much space.
Old 23rd Aug 2005, 18:25   #17
Highland3r
I Mod, Therefore I Own
Highland3r is on a distinguished road
Nice review guys, looking forward to a Pentium M based shuttle...
Any chance someone can PM/email or whatever me details of the tests you ran (compression/encoding etc) on this system... Would'nt mind running through some tests with Dual Channel and a little more on the FSB front just too show/see how much of a difference these really make to the M's.
__________________
Prawn or not...?
Highland3r is offline   Reply With Quote
Old 23rd Aug 2005, 18:31   #18
charl3s_fatal1ty
Guest
Posts: n/a
lol. go bindi!!
looks pretty nice for a media centre PC but as you say, I'd got with an Athlon 64 or X2 for really demanding stuff like games
Old 23rd Aug 2005, 19:53   #19
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
AutoGK 1.96, custom sized Dr.Who mpeg2 recording from freeview, about 15 mins of one of the episodes. I basically set it to auto and 174meg xvid output and it does the same thing every time.
MP3 Encoding is using DBPowerAMP, copying to wave first off moby-play CD then trancoding it into mp3 using the standard lame encoder.
HD WMV is the T2 clip off the MS website.
Old 23rd Aug 2005, 21:15   #20
Hackjedi
Minimodder
Hackjedi is on a distinguished road
Deep Blue
you must be working at the shop I visited this afternoon. A well known shop here in the Netherlands sells a high end game system and on the display it said:
"The best gaming experience with the new 6200 turbocatch"
L(*)L
__________________
Casemodders are the best photoshoppers in the world
Hackjedi is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
