#1 |
Born to be...
The "Freeze a CRT" thread :)
I'm in the process of freezing a CRT. For the prolouge go
Pics and stuff tomorrow. I have little or no wood at home for this so this might take a day or so to kick off... Main concerns at present time:
* The first one turned out all hazy thus atleast one try with the aim of clear ice is justified. Edit 22th February 2006 (In Sandy Brown)
__________________
"My grandfather died in the concentration camps, fell out a watch tower and broke his neck" I am teh 1337: [Frozen CRT] | [Wellpapp] Deus ex machina -> "Deh-oose ex ma-kee-nah" 55.02959% geek- Extreme geek. Get geek rated today! Last edited by Vigfus; 22nd Feb 2006 at 21:28. Reason: Updated n' stuff |
#2 |
Born to be...
Thank you cind sir. I am but a humble pioneer in the cryogenics field.
__________________
"My grandfather died in the concentration camps, fell out a watch tower and broke his neck" I am teh 1337: [Frozen CRT] | [Wellpapp] Deus ex machina -> "Deh-oose ex ma-kee-nah" 55.02959% geek- Extreme geek. Get geek rated today! |
#3 |
Born to be...
With plywood walls it would most certainly not break, just think how you can abuse the monitor in normal situations. With even pressure around it it would survive. I think... Well' see.
__________________
#4 |
Born to be...
Will think about this when i go to sleep toningt, right now actually...
Well that avatar didn't stay long.
__________________
#5 |
Born to be...
The victim:
![]() ![]() That mouseholder will have to go, or is it really cool? Da bumpersticker up close: We can clearly see the differences in what our country's mentality is like from this image. Translation (Partial...): [Whatever the german says, i see the 29.5kv and assume they are tellign everyone how dangerous that is] [Danish] This appliance Must be connected to a grounded outlet. (Note the capitalisation on "must") [Swedish] If this appliance is connected to a telecommunications network it must be connected to a grounded outlet. [Finnish - ???] Hope the other two languages support what im saying. ![]() The grave ![]() I have some wood to build from, lets hope i won't have to go shopping. Will take some photos during the build, if anyone is interested... It's just a box anyways... I will be aiming for 1-2cm thick ice around the monitor. GJ on the freezing there malf.
__________________
#6 |
Born to be...
First cut + drawing:
![]() Glueing one side: ![]() I needed to extend this a little, otherwise i had to go shop and i'm not in the mood for that. After cutting this and putting the glue on i was struck by a blinding realisation. My sister has all my tools atm so this will just have to cure as best it can (those are the only clamps i have that's long enough) and i'll stick someting over that joint later...Maybe i'll go get my tools today. Otherwise they will arrive tomorrow...
__________________
#7 |
Born to be...
Yeah, but frozen = sub zero.
Update coming, box complete and testfilling with water. To see if it can still keep itself in one piece and to see if i will be able to get it out of the freezer. (Its filling right now so the update migth be postponed )
__________________
#8 |
Born to be...
Yay tools!!!
![]() I sawed the combined thingy in half, the glue hadn't cured yet. (And won't) ![]() Pieces of a late tabletop. ![]() The "floor", an old catscratching-pole-mounting-plate. Fur removed, slightly shortened... ![]() The freezer, again, after the cipping out of lots of ice. (It wouldn't fit )![]() The ice. ![]() I glued and screwed the first wall, the rest was just screwed, or i would never be able to take it apart. Higher res + ruler: ![]() ![]() ![]() The box + the display + the mom ![]() Nice fit ![]() Filling, went ok. I need a bigger bag though, it didn't quite fill out in the corners... Thanks to ImageShack for Free Image Hosting It's really heavy, might need some help getting it out of the freezer. ![]() And the mouseholder had to go, regardless of your preference as to the coolness...
__________________
#9 | |
Born to be...
__________________
#10 |
Born to be...
4.55*4.10*4.20 = 78,351 ~ 80l ~ 80 kg ~ 176.36981 pound
Yes it's cool, thats why. I'll recap since the treasurehunt is now deleted... We were searching for something frozen in ice. I, as a joke, suggested someone should freeze a CRT. After a while i got to thinking... I had an extra monitor, some space in the freezer. Plus a burning desire to do wierd stuff. So there ya have it...
__________________
#11 |
Born to be...
Better sig?
![]() The only thing i see taking up room is the tube itself, as the rest will be flooded. As the corners of the box are not completely filled out i think this negates any weightloss incurred by the monitor.
__________________
#12 |
Born to be...
Test sample?
__________________
#13 |
Born to be...
No, that will be done all in, eh, two goes. But i might wait until i have some way of getting it out of there. Im thinking a pulley and that other thing (many pulleys together)...
__________________
#14 |
Born to be...
That'll work, not.
And why would i put it in upside down? Wouldn't it work out the same way if i just turned it over when finished, very easy to do btw? Edit: Haha, found it. But i bet you don't use them (the words) the same way as we do in Sweden. Block och talja = Pulley and tackle. More edit: Well i guess you do, almost... Clicky
__________________
"My grandfather died in the concentration camps, fell out a watch tower and broke his neck" I am teh 1337: [Frozen CRT] | [Wellpapp] Deus ex machina -> "Deh-oose ex ma-kee-nah" 55.02959% geek- Extreme geek. Get geek rated today! Last edited by Vigfus; 26th Aug 2005 at 22:17. |
#15 | |
Born to be...
__________________
#16 |
Born to be...
Not sure, the anchor would probaly need to be emersed quite some length, this could be done with wires but that would ruin the effect... Or look even cooler. I think i'll go with screwing into the frame, need some longer sqrews though, and maybe some mounts.
I guess a trip to the store was inevitable... ![]() A thought, what should i do with the monitor cable? Something artistic, let it hang out or what?
__________________
#17 |
Born to be...
Would it support the 80kg? It's old dried out and specifically not made for this...
I would still need to prepare "plan b" if it broke. Remember, it will be -20C when lifting it...
__________________
#18 |
Born to be...
No progress. I might go buy a block and tackle, or just some pipes and string to make my own. I also need to find a beam in the roof, preferrably exactly above the freezer...
__________________
#19 |
Born to be...
I didn't make it to any store, will get the suspension sorted this evening...
I'm thinking about ways to make the suspension movable about one meter to the side... It might be to complicated though.
__________________
#20 |
Born to be...
Lifting device
Since i have no long screws i will not be able to get this up tonight. But i can do the pieces... One of the many joys of living near a factory is the containers. If you need something you allways go here first. Pipe and wheel: ![]() Bent from stress test... ![]() Will make a nice "slider". I would like to use it as a roller, but that would require a much too flimsy pipe... Is this: ![]() Or this the best option? ![]() Not using a screwdriver ofcourse. ![]() I was thinking about moving the freezer too. I would if i had more space. As of now i have trouble getting the lawnmower out of there. In fact it is banned from the garage until this project is over. Will get a pic of the mess on the next update...
__________________
| Thread Tools | |
| View Mode | |
