Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Intel Pentium 4 670 & Pentium D 820
__________________
#2 |
I Mod, Therefore I Own
im curious as to whether you forced cpu affinity during the multi-tasking benches?
i've noticed that XP seems to be really crappy at dividing processes between the 2 cores sandra and BF2 are really good examples of this: Sandra cpu benchmark is multi-threaded - it uses 100% of both cores Sandra Mem bandwith benchmark is single-thread but SMP aware - uses 100% of 1 core BF2 is horribly coded pos - it uses 100% of one core then 100% of the other, it alternates between coresi've noticed this a lot, so when im going to be doing some heavy multi-tasking i usually force te affinity of the 2 apps to different cores, this seemed to make a big difference (it also helps with stability of certain apps, bf2 for instance cant stay connected to a server for more than about 2mins if you dont force the affinity to 1 core or the other )
#3 |
Pewlius Caesar
bit-tech Staff
I did, where possible
__________________
#4 |
okey dokey
![]() did you notice any of what i was talking about with either chip? im wondering if its an XP problem (most likely tbh) or an AMD thing also, could you stick the numbers on the multi-tasking graph for the same chip but without the multi-tasking bit, so we can see how many fps you drop by runing XYZ in the background?
#5 |
Pewlius Caesar
bit-tech Staff
I don't have the X2 4800+ anymore, unfortunately
__________________
#6 |
Why not? I own a domain to match.
About what I expected for results :P
Now Newegg is making my head spin (though that could be because it's 6am and I'm just getting ready to go to bed...) all of the 945p, 945g (one is ATX and one is BTX I think) and 955XE (or whatever letters) chipsets support the dual core LGA procs, right? Either I'm confused or newegg needs to update some compatibility notes. The 820 seems like a good deal all things said and done. Not for gaming, but for everyday use anyways. I love my A64 for gaming, but I still miss how smooth everything felt with hyperthreading. And dual core pwns hyperthreading. *ponders setting up a flash countdown to me having enough 'spare' cash for an X2*
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#7 |
Modder
My ass prescott has a better performance:watt ratio then northwood
__________________
no, your face. |
#8 | |
Pewlius Caesar
bit-tech Staff
__________________
#9 | |
Officious Bystander
#10 | |
Lazy Lurker
I noticed a mistake on the first page
In response to your question about anyone gaming at low resolutsion with a good card, I hate to say it, but there is one person I know who insists on playing Counterstrike at no more than 1024x768 on his 6800 GT. ![]() Im surprised no one as of yet has taken an 820 and compared it with a 520 or 620 processor... thus far theres been no test to show exactly HOW much performance difference there is between two cores and hyperthreading at the same clock speeds. Overall a pretty nice review bigz; you do seem a tad rusty though compared to previous reviews. By the way, do you think you used the word "workhorse" enough on the last page?
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#11 | |
Pewlius Caesar
bit-tech Staff
![]() Presler is what I would call 'two separate cores installed on the same packaging'. Presler will improve yield because you can pick any two cores and install them on the same packaging. On the other hand, Smithfield requires two good cores to be next to each other on the wafer as they are physically attached.
__________________
#12 |
Lazy Lurker
You would be correct; I had not seen that picture
My mistake, sorry ![]() Do you have any inkling as to why it would require two good cores next to each other? they dont communicate with each other over the die, and might as well be completely seperate processors
__________________
| RotoSequence |
#13 |
Richard Swinburne
bit-tech Staff
Space on the package - look at the space required between the dual core 65nm's and you'll see why.
#14 |
Lazy Lurker
I dont see whats stopping them from putting a millimeter or so's distance between two dies though... are you catching something else visually that I'm not?
__________________
| RotoSequence |
#15 |
Pewlius Caesar
bit-tech Staff
It is the way that the architecture works - Intel have opted for a shared bus because of the limitations of not having the memory controller on-die. AMD share the memory controller and the HyperTransport bus and the cores are connected before that, Intel's current dual core technology does not allow communication on-die because it still needs to talk to the northbridge (AFAIK).
__________________
#16 | |
Pewlius Caesar
bit-tech Staff
__________________
#17 | |
Lazy Lurker
__________________
| RotoSequence |
#18 | |
charl3s_fatal1ty
Guest
Posts: n/a
| charl3s_fatal1ty |
#19 | |
Richard Swinburne
bit-tech Staff
#20 |
Brett Thomas
A note to Hamish,
It's XP that controls thread assignments. It's entirely buggered and I'd love someone to write a competent third-party piece of software to direct the cores. I've been bitching about this since the advent of HT. Perhaps they'll fix it in longhorn? I won't hold my breath, however...it's why I haven't really seen dual core as all THAT great a thing...I get sick of babysitting my HT, much less an entire damn second core! It will improve DRASTICALLY when MS pulls its thumb out and actually starts to develop a bit smarter version of thread prediction/assignment. Not the easiest thing in the world to do, but if they just bothered I'm sure it would show up in no time.As for the article, great job as usual, biggles, but I agree with the comment about being a little rusty on the pure non-graphics hardware end...may wish to stick to writing with bindi on this topic. You're tackling the whole article the same way you would a GPU, and it's just not quite the same thing. I wish I could explain what it is about it, but the whole thing just feels like I read about a new gfx card as opposed to a CPU line. Also, info on O/C would be useful...this chip is a lower budget chip in the dual core market...would be nice to see how high it successfully cranks...I'm also concerned about the heat output when you OC dual cores on the same chip. Maybe cover in another article along with the A64 X2? It'd give you a reason to get the chip back, at the very least.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
| Thread Tools | |
