#1 |
Supermodder
securing ur internet from goblins n...
horrible stuf
![]() one your sever, wot o/s do u have? wot fire wall do u run ? wot specs is your machin ? had any problems ? , reason for askin is cos ive got a p3 450, 192 meg of ram, 80gig. for me server, i was thinkin win 2k server. and ISA. wot u think. no need for any fire wall extra software then ![]() Jonny (Tar)
__________________
gone with puff |
#2 |
Wheres my plasma cutter?
2000 would be my bet.. very stable system.. try doing a search for "iis hardening" on google for some security pointers..
-scoob8000 |
#3 |
Mod Master
I run a P3 450, 512mb PC133, 40gig IBM Deathstar, running Win2k pro (don't own server) for firewall I have a smoothwall box only.
#4 |
Supermodder
cheers mate, anymore ?
__________________
gone with puff |
#5 |
Whats the server for? You verywell may not even need the server version, unless of course you want to use it's integrated services..
...It couldn't hurt to use Zonealarm or similar I suppose, but 2000's IPSEC does work pretty nicely, I use both on my 2000 pro. machine.. -scoob8000 |
#6 |
Supermodder
wel the server is for
![]() [1] routing the internet to a hub, and the other 8 machine in my family... [2] to serve as a file backup, hence the 80 gig. [3] to be used as a fire wall, or some kind of an internet connection barrior. ukno ![]() [4]to just keep an eye on things basically ![]() Thanks mateies
__________________
gone with puff |
#7 |
Spaceman Spiff
try tiny firewall...its quite good...
__________________
...wordEs...
#8 |
EvE Addict
id reccomend tiny personal firewall and use pc anywhere, with that you can access the desktop of the server and control it from your pc, tis quite a nice little prog. Then you dont need a big screen and you can keep ya server box in a cupboard or wardrobe
__________________
|i5 2500K| |P8P67| |8GB DDR3| |GTX 580| |Corsair F3 120 SSD| Last edited by Cruelinios; 30th May 2002 at 22:07. |
#9 |
Supermodder
anyone got a link to tiny firewall pwease
__________________
gone with puff |
#10 |
Multimodder
Here's the Goodies.
Here's a link for Tiny Personal Firewall 3.0 download, released on 01.05.2002...
www.majorgeeks.com/article.php?sid=760 Enjoy! Muhahahahahaha... LOL!!! :dude:
#11 |
True Friend
http://www.openbsd.org
Probably the best unix-like OS to start off with as a firewall, as it comes fairly secure out of the box. I personally use FreeBSD for my routing/firewalling, but it's just personal preference. OpenBSD has gone through a line-by-line code audit (and still is) so it is considered to be one of the most secure OSs available.
__________________
Your sig was too large and has been removed - 10/10/2005 We ask that you keep your signature to 4 lines or less at the standard font size. |
| Tags |
| network |
| Thread Tools | |
