RSS
Old 6th Sep 2005, 16:33   #1
WilHarris
Just another nobody
WilHarris's Avatar
WilHarris is on a distinguished road
ATI All-In-Wonder X800GT
http://www.bit-tech.net/hardware/200..._x800gt/1.html
WilHarris is offline   Reply With Quote
Old 6th Sep 2005, 18:35   #2
Stompy
Ultramodder
Stompy is on a distinguished road
Sorry if I missed it, but how much does it cost?
__________________
PC (Now out of use): Athlon 64 3000+ Winny | Asus A8N-SLI | 1024mb OCZ Premier | 6600GT 128mb | 160GB WD | NEC 3520 DVDRW | Coolermaster Centurion 530 | Hiper Type-R 480w
Laptop: Dell Studio XPS 13 | Core 2 Duo P8600 2.4ghz | 4gb Ram | GeForce 9500M 256mb | 320gb 7200rpm | DVDRW | 13.3" LED WXGA
Stompy is offline   Reply With Quote
Old 6th Sep 2005, 18:43   #3
MrWillyWonka
Moderator
MrWillyWonka's Avatar
MrWillyWonka will become famous soon enough
Good for a media centre PC I guess, but not for a high spec rig, 128mb is outdated. It would however save PCI space I guess (Not needing a TV card).
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors
MrWillyWonka is offline   Reply With Quote
Old 6th Sep 2005, 18:53   #4
herbs
Nobody but us chickens
herbs's Avatar
herbs is on a distinguished road
Shame the card has a rage 200 chip not the newer rage 550 chip as it probably would have helped in the picture quality on the analogue side. Also I didn't notice in the review if the card supported interactive features of dvb-t such as mheg5 and electronic program guide for schedule recordings or just to see whats up coming, it would be nice to know if the software supports it. I doubt it though as most tv card manufacturers seem to have problems supporting mheg5 and dvb-t radio.
__________________
A police recruit was asked during the exam, "What would you do if you had to arrest your own mother?" He said, "Call for backup."
"you could have it all, my empire of dirt, I will let you down, I will make you hurt"
herbs is offline   Reply With Quote
Old 6th Sep 2005, 18:55   #5
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
The card is not available for purchase yet, and as such we don't have an expected retail price at this moment in time.
Tim S is offline   Reply With Quote
Old 6th Sep 2005, 18:58   #6
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I'm not sure about mheg5, but it definitely has electronic program guide in the states - I've never been able to get it working properly in the UK. DVB-T might help on that front though as it was capturing the screen caps by program name rather than channel.
Old 6th Sep 2005, 21:05   #7
herbs
herbs's Avatar
In the UK the 7/8 day electronic programme guide on dvb-t is broadcasted over the air, I suspect your saying that the card uses something like gemstar or some other tv listing downloaded from the net. I also suspect ATi will use something like www.tvtv.co.uk if they do provide listings for the UK, which in my view is not ideal.
__________________
Old 6th Sep 2005, 21:26   #8
Boon
Supermodder
Boon is on a distinguished road
Any more info on the Scart output? Presumably it outputs an RGB signal? Is the res limited to standard ATI TV Out presets or are you able to custom res so that you can output a true widescreen res? Just wondering as there are many who currently use a custom cable and this could be the out of the box solution others have been looking for.
Shame there seems to be no way to get an audio signal to the scart.
Boon is offline   Reply With Quote
Old 6th Sep 2005, 22:25   #9
herbs
herbs's Avatar
What are you talking about arnold ! its svid that doesn't carry sound, scart cables do carry sound.
__________________
Old 6th Sep 2005, 22:38   #10
Boon
Supermodder
Thanks for clearing that up... I was actually refering to the specific Scart output on the Radeon which may or may not allow a line in signal to be transmitted with video. A custom cable would be pretty easy to make either way that would combine the video with an external audio input but I was thinking about an off-the-shelf solution for us RGB Scart advocates.
Also just out of interest who's arnold when he's at home?
EDIT: Having said that a closer look at the multi-cable I/O lead that comes with the All in Wonder you can clearly see what looks like a line out input to the Scart so that you could connect it easily to you soundcard to transmit audio. Now just interested in resolution support.
Old 6th Sep 2005, 23:33   #11
herbs
herbs's Avatar
Actually I should have said what are you talking about willis, lol my memory is going you see after 30 its downhill.
__________________
Old 6th Sep 2005, 23:44   #12
Boon
Supermodder
Ahhh... Willis.. that I know..
Old 6th Sep 2005, 23:52   #13
alextwo
alextwo's Avatar
alextwo will become famous soon enough
Thunderbirds! Got to love daytime TV
__________________
flickr
alextwo is online now   Reply With Quote
Old 7th Sep 2005, 16:00   #14
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I don't know but if you tell me which output you want me to find that out for - I'll have a look and roll my Rear Projection in to my office if need be.
Old 7th Jan 2006, 08:37   #15
davejp
What's a Dremel?
davejp is on a distinguished road
Was the issue of scart connecivity ever answered?
I need to know if it outputs RGB and if I can set a res of 1024x576 for instance. (or other true w/s resolutions)
Thanks
Dave
davejp is offline   Reply With Quote
Old 7th Feb 2006, 14:29   #16
webbyman
Hax.
webbyman's Avatar
webbyman is on a distinguished road
am i the only one who noticed?
the lable BREST under neither her breasts
webbyman is offline   Reply With Quote
Old 7th Feb 2006, 14:38   #17
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
thanks for reviving an old thread for no reason other than to spam it with crap...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
