Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 21st Apr 2011, 13:39   #1301
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on youstonedsurd - may the hammer of Bindi be bestowed on you
Orange would clash horribly with the interiors, IMO.
__________________
stonedsurd is offline   Reply With Quote
Old 21st Apr 2011, 16:44   #1302
Xen0phobiak
SMEGHEADS!
Xen0phobiak's Avatar
Xen0phobiak has yet to learn the way of the DremelXen0phobiak has yet to learn the way of the DremelXen0phobiak has yet to learn the way of the Dremel
+1 for a variant of beige here. I'd go with Ford Platinum Metallic personally.
__________________
In an emergency situation involving two or more officers of equal rank, seniority will be granted to whichever officer can program a vcr.
World of Tanks profile
Xen0phobiak is offline   Reply With Quote
Old 21st Apr 2011, 17:26   #1303
Techno-Dann
Disgruntled kumquat
Techno-Dann's Avatar
Techno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the DremelTechno-Dann has yet to learn the way of the Dremel
Agreed with Stonedsurd, orange would clash with the interior. Black would match best, but BRG is really the only option.
Techno-Dann is offline   Reply With Quote
Old 22nd Apr 2011, 07:22   #1304
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
Black without a doubt. Would go very well with the interior.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 22nd Apr 2011, 08:03   #1305
xrain
Supermodder
xrain's Avatar
xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.xrain is a hoopy frood who really knows where their towel is.
Any color, so long as it's black.
xrain is offline   Reply With Quote
Old 22nd Apr 2011, 23:34   #1306
Prometheus
Supermodder
Prometheus's Avatar
Prometheus has yet to learn the way of the DremelPrometheus has yet to learn the way of the DremelPrometheus has yet to learn the way of the DremelPrometheus has yet to learn the way of the DremelPrometheus has yet to learn the way of the DremelPrometheus has yet to learn the way of the Dremel
Tough decision, I think black really suits it. How about either a very very dark green that looks black unless in the sun etc or a black that has a hint of green in it.
__________________
Project: MUSE (may one day get a project thread when i've got time)
Prometheus is offline   Reply With Quote
Old 27th Apr 2011, 20:50   #1307
GreatOldOne
Wannabe Martian
GreatOldOne's Avatar
GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!GreatOldOne - it's over 9000!!!!!!!!1!1!1!!!
A little bit of titivating, before I go off to the Stoneliegh show at the weekend. I've added a small bead around the inner edge of the wooden dash surround, and added the D shaped bead to the outside edge of the dash and to the door caps:
The inner bead matches the trim around the boot panels, and has been glued on with impact adhesive. The outer bead is sandwiched between the fibreglass and the wood, and is held there once the wood has been tighten up pinching the flange. Same goes for the door caps. It's a small detail, but i think it makes a big difference.
I've also finished the metal end caps of the wooden door tops:
Lots of filing, lots sanding through endless grades of wet & dry, and then polished up using 3 different mops.
Kerchow!
__________________
"Maybe we're on Mars because we have to be, because there's a deep nomadic impulse built into us by the evolutionary process, we come after all, from hunter gatherers, and for 99.9% of our tenure on Earth we've been wanderers. And, the next place to wander to, is Mars. But whatever the reason you're on Mars is, I'm glad you're there. And I wish I was with you."
- Carl Sagan
A GOO-ster is Born - Build Diary RSS I'm a Great Oakley product tester! My purpose built testing centre
GreatOldOne is offline   Reply With Quote
Old 28th Apr 2011, 08:15   #1308
BentAnat
Software Dev
BentAnat's Avatar
BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!BentAnat - it's over 9000!!!!!!!!1!1!1!!!
Looking GREAT, GOO.
The camera still makes the interior look more pink than anything else, though...
BentAnat is offline   Reply With Quote
Old 28th Apr 2011, 08:43   #1309
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Nice tweaking there GOO, are you going to take it all off for painting?
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 28th Apr 2011, 10:02   #1310
GreatOldOne
Wannabe Martian
Yep. I'm going to drive her to the body shop so they can take a look and see the complete car, and give me a quote. Then I'll strip all the body work off one weekend, and then take it up in a van.
Once it's been painted, I'll bring it back and then take as long as required to get it all back on without scratching the new paint.
BTW - I've decided. It's Black.
Probably BMW Jet Black. But I'm open to sugestions as to which black... I'm not sure wether a metallic would look right, unless there's a metallic black out there that doesn't look blue-ish in the sun. I want a nice deep black.
__________________
- Carl Sagan
Old 28th Apr 2011, 10:11   #1311
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
If it's black I much prefer it with just a tiny metallic fleck into it, I don't think just a flat black would look quite right on such a curvy car. I like the BMW Diamond Black for that, not too shiny, just enough, the old E30 M3's look absolutely stunning draped in that.
Once it is painted I'm sure the bodyshop can recommend some covering to protect it a bit while you put it back together, some kind of plastic wrap would be good for everything but gouging with a screwdriver.
__________________
Old 28th Apr 2011, 10:20   #1312
GreatOldOne
Wannabe Martian
I take it the Diamond Black has a silver metalic flake in it?
__________________
- Carl Sagan
Old 28th Apr 2011, 10:41   #1313
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Yep, from memory at least, I've not seen a definite Diamond Black BMW in ages now.
__________________
Old 28th Apr 2011, 12:38   #1314
Smilodon
The Antagonist
Smilodon's Avatar
Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.
BMW do have a slightly "warmer" black metallic. The flakes will have a brown-copper-ish tint in the sun. It's a very nice color, but I can't remember what it's called. I'll have a look around the carpark at work tomorrow.
And good choice on black, BTW. I don't think you'll regret it.
I have one suggestion: On the woodwork, what about making a 5-6mm wide pinstripe to the face of the wood trim? (In the same color as the car). It could help it "blend" the interior with the exterior.
__________________
"You have to wonder about a business plan based on the notion that people want to interact with a soda can." -Jeff Salkowski abot the :CueCat
"City crematorium. You kill 'em, we grill 'em." -Rkiver
Smilodon is offline   Reply With Quote
Old 28th Apr 2011, 13:52   #1315
IanW
Grumpy Old Git
IanW's Avatar
IanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpit
In this week's "Wheeler Dealers" on Discovery, Edd Chyna used some clean old towels to protect the freshly applied paint on a Frogeye Sprite he was re-assembling.
Or you could get a roll of bubblewrap from a local packaging company (probably a better way to keep on Mrs GOO's good side.)
__________________
i5 2500K@3.3GHz / Corsair H50-1 / Asus P8P67-M PRO / 16GB Corsair Vengeance / MSI GTX670 / 240GB Samsung 840 /
1TB HDD / Silverstone 600W / Silverstone SG-09 / Dell U2713HM / CM Storm Quickfire TK / Logitech G9 / Win7-64 Ultimate / Ubuntu 13.04-64
IanW is offline   Reply With Quote
Old 28th Apr 2011, 15:05   #1316
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpitXir is almost as Godly as yodasarmpit
I still think he's fooling us and the interiour is pink indeed
Admid it, and the outside is going to be mint green to really go with the pink.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus something 1920x1080
Xir is offline   Reply With Quote
Old 28th Apr 2011, 17:26   #1317
GreatOldOne
Wannabe Martian
Ed Chyna = Legend. I find Brewer an irritating little git though, but that's what the FFWD button is for.
I thought the Sprite was cute - they always look like they're happy. And the new paint was so much better than the red it was in originally.
__________________
- Carl Sagan
Old 28th Apr 2011, 18:33   #1318
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
THIS!
I can't wait to see it in full paint, especially now that you've chosen black! I personally recommend microfibre towels for protecting it as well, and I'm sure you know this but I'll mention it anyway - be very careful with the new paint, it can take weeks to cure properly even when it is baked after being laid down.
Unicorn is offline   Reply With Quote
Old 28th Apr 2011, 19:23   #1319
IanW
Grumpy Old Git
IanW's Avatar
Agreed. Every time I see a Sprite, I end up with as big a grin as the car!
__________________
Old 5th May 2011, 07:18   #1320
GreatOldOne
Wannabe Martian
I think I've found the paint for Vikki - Jaguar Black Cherry Metallic:
It's black, but with a subtle red flake in it. When the sun catches it, it's a very, very dark red, but in all other lights it's black.
It looks great in the flesh - I stopped at the local Jag garage yesterday to have a look, on the way back from getting Heinken Cup Final tickets (Coooome oooooon yoooou Saaaaaiiiints!). Great way to spend your birthday.
__________________
- Carl Sagan
Reply
Tags
arduino, awesome, bmw straight6, build, car, crazy grins, custombuild, electronics, goo, gooster, greatoldone, kitcar, legendary, motors, say no to skimlinks, sweet jesus, vikki
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
