Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 15th Sep 2005, 12:00   #1
Howie
What's a Dremel?
Howie has yet to learn the way of the Dremel
Total Annihilation server
Hi,
Its good to see so many of you still play TA
I have played TA for years on my LAN.
Can anyone help me on how to set up my TA as a server so my mate can connect to my game via WAN ?
Do i need some server/client software ?
Thanks
Howie is offline   Reply With Quote
Old 15th Sep 2005, 21:30   #2
markit
Multimodder
markit's Avatar
markit has yet to learn the way of the Dremel
Total Annhilation doesn't use Servers, he/she will need to connect directly by finding out your IP address
markit is offline   Reply With Quote
Old 15th Sep 2005, 22:12   #3
Howie
What's a Dremel?
Hmm i cant even connect on my lan via IP I have to use ipx/spx
Is there something i should know ?
Old 16th Sep 2005, 08:37   #4
LockmanX
Supermodder
LockmanX's Avatar
LockmanX has yet to learn the way of the Dremel
Hosting and connecting to a TA server on the internet is pretty easy. First, make sure the computer it's hosted on can be directly connect to via its IP (set it up as the DMZ if behind a router). Make sure the firewall is happy with TA. Give the computers IP to whoever you want to play with.
Now open up TA and go into multiplayer. When the box asking for the address comes up, leave it blank and hit OK. Now you should come to a server viewer style of thing. Hit create. Once you've got a lobby going, people can connect. Have them open up multiplayer. When they come to the screen asking for an address, have them enter your IP. Now when they are in the server viewer, they should see your game and be able to join your lobby.
Note that everyone MUST be running the same version of TA and that mods can kink up the works. If you are having version/whatever conflicts, I found the easiest fix was to just send them your TA folder and run from that.
There are no dedicated hosting solutions but TA being as old as it is, its hardly an issue. Ventrillo/Teamspeak makes cooridinating things a bit easier and it adds a new layer to the game being able to talk to your opponents.
As for LAN play, they should be able to see your game lobby in the server browser without having to much about with giving them the IP.
If I screwed up or a better write up is requested, I could probably get round to it later today. This is the method I've used to play TA with friends all over the place.
LockmanX is offline   Reply With Quote
Old 16th Sep 2005, 18:11   #5
OtakuHawk
The Post of The Beast
OtakuHawk has yet to learn the way of the Dremel
TA is the best real time strategy ever.
On most maps it gives you options other than just rushing.
The rock-paper-scissors aspect is infinitely complicated,
and unit combos are a must.
__________________
Ultra-Lurker
OtakuHawk is offline   Reply With Quote
Old 11th Dec 2007, 07:34   #6
Twilight
What's a Dremel?
Twilight has yet to learn the way of the Dremel
Looking for online Total Annihilation players (TA: Twilight)
I know there are still people who play Total Annihilation online. We usually play Total Annihilation:
Twilight, itself descended from Absolute Annihilation and Uberhack, and would love to have more people to
play with online.
The website is here:
http://twilight.tauniverse.com
and the latest version is here:
http://twilight.tauniverse.com/downloads.html
What is Total Annihilation: Twilight? The list below, while certainly not comprehensive, summarizes some
of the more notable features.
- Original Total Annihilation Feel
- Well Balanced Units, Structures, and Overall Gameplay
- Great Strategic and Tactical Depth
- New Units to Fill Strategic/Tactical Roles
- Improved Models
- Newly Added Sounds
- Errors and Bugs Fixed
- Single Player Campaigns Enabled
- Balanced Expressly for Multiplayer
- AI Built From the Ground Up
- Customizable AI Profiles
- Multi-Directional Factories
- Improved Loading and Unloading for Transports
- Nano Turrets and Fortification Turrets
- Larger, More "Naval" Feel to Ships
- Devastating Nuclear Weapons Worthy of the Name
- New Experimental Gantry Units On Both Sides
About Total Annihilation: Twilight
What is Total Annihilation: Twilight? Put simply, TA:T is an extension of OTA (Original TA), balancing
old units and adding in new ones, as might have happened had Cavedog (The maker of Total Annihilation)
not gone out of business and continued to update TA.
TA: Twilight strives to make all of the original units useful, as well as adding in new ones to fill
strategic roles, all while keeping the original TA feel. While there are many units, they have been added
for the purpose of filling specific roles and to generally improve gameplay and fun, and not just so we
can say we have lots of units. The idea is that every unit should have a good reason to be built and
used. There are some units that are more specialized, and whose ideal situation may not happen all of the
time, but the goal is to never have a unit that is just not worth building, either because it is
worthless in the first place, or because other units do what it does just as well. Some overlap is fine,
as long as each overlapping unit has a solid reason to be built in and of itself.
While the focus of TA:T is on multiplayer, much work has gone into trying to make the single player
(Against the AI) experience as fun as possible. The AI for TA:T has been built from the ground up, and
includes multiple options to focus the AI on a specific type of game. For example, you can set the AI to
build only aircraft, or only level 1 units, etc. All of these AI settings take only a few keystrokes to
enable.
From the Absolute Annihilation Twilight Betas to Total Annihilation: Twilight
Here's the short summary of where we came from:
Twilight had been a player of the Absolute Annihilation mod for quite a while (Which was itself descended
from the very popular UberHack TA mod), but when Caydr, the maker of Absolute Annihilation, decided to
stop supporting the OTA version and only release new versions for the Spring engine, Twilight asked for
permission to continue to work on AA and release new versions of it.
Caydr granted this permission, and so since about November of 2005, Twilight had been maintaining and
releasing "Twilight Betas" of Absolute Annihilation, which continued to fix bugs and adjust balance
issues found in AA version 6.0. For a few months the forums had been hosted at Caydr's own website,
www.caydr.com, but an announcement on the front page of the site on January 30th, 2007 stated that he was
too busy to keep the site going, and was going to let it lapse. The "Twilight Betas" had changed things
substantially since Twilight had taken over development, and he wanted to avoid confusion between the
latest "Beta" (Released February 13th, 2007) and the last "official" release of Absolute Annihilation for
the TA engine (Instead of the Spring engine), which was put out in the summer of 2005. Because of this,
Twilight had been planning to break off and rename the mod, so that he could drop the tenuous "Beta"
pretense, and just develop this new mod officially. Caydr's announcement sounded like a good excuse to
get that moving, and so, with deep thanks to TAUniverse's gracious hosting, Total Annihilation: Twilight
began!
Since taking over in November 2005, Twilight released about 12 new "beta" versions of the AA mod, ending
with Twilight Beta 5.7. Instead of 5.8, the next version was Total Annihilation: Twilight v1.0, released
in March of 2007 (Lately there is about 1 new version released every month or two, depending on the
number of changes made). TA:T is now up to version 1.5a, and Twilight continues working with the
community on fixing bugs, balancing units, adding in new units to fill needed roles, etc. TA:T has a
small but active community who post quite frequently in the forums regarding balance, new ideas, etc, and
we usually have several multiplayer games going on each day and evening.
We are a very welcoming and friendly group of people, and primarily are looking to find new people to
play with on-line and introduce to the fun of TA. We have started a tournament recently, but generally
just play friendly games. Veteran players and newcomers alike are both welcome!
You can contact me through MSN Messenger or email with twilight13[at]gmail.com.
Thanks, and I look forward to playing with some of you on-line.
Twilight
Twilight is offline   Reply With Quote
Old 19th Feb 2008, 00:54   #7
EskimoJoe
What's a Dremel?
EskimoJoe has yet to learn the way of the Dremel
If anyone ever wants to play me
Hey all,
If anyone ever want to play me in a game of total annihilation/absolute annihilation, just IM me or PM me to set up a time and we can get a killing!! Take care and kill ya soon
EskimoJoe is offline   Reply With Quote
Old 19th Feb 2008, 01:09   #8
Veles
DUR HUR
Veles's Avatar
Veles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the DremelVeles has yet to learn the way of the Dremel
You could use Hamachi to set up a virtual LAN you can use for TA
__________________
Veles on: Xbox Live (My Halo stats), Steam Community, Twitter
Originally Posted by Fod View Post
spam gangsters might as well tap into all those machines for their zombie networks.
Veles is offline   Reply With Quote
Old 19th Feb 2008, 04:32   #9
EskimoJoe
What's a Dremel?
How so? I don't know what Hamachi is
Old 19th Feb 2008, 07:48   #10
Veles
DUR HUR
Veles's Avatar
https://secure.logmein.com/products/...pn.asp?lang=en
Everyone downloads it and sets it up, it gives you a tutorial when you first boot it up
One person creates a group and invites everyone, when you have hamachi booted up and everyone logged in it acts like you're all on a network so you just go to LAN games and you can connect to each other just like if you would normally if you were on a LAN, using your hamachi IP as the IP address. If you look in your network connections you'll see that hamachi creates a new hamachi network connection.
That's a pretty bad explanation but I'm sure you can get the jist of it from that.
__________________
Reply
Tags
pc, pc gaming
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
