#1 |
Just another nobody
First-Look: Dell XPS 600
http://www.bit-tech.net/hardware/200...xps_600/1.html
Certainly looks like an interesting system - we're looking forward to getting it full working and seeing how it actually performs and evaluating the bundle! |
#2 |
Evil Teddy
Could they have made it any more messy in the inside of that case. Why not use rounded cables or sata hard discs??
I see they've got a long way to go to reach the levels of voodoo, alienware etc when it comes to finishing touches.
__________________
modding.gordyhand.co.uk |
#3 |
Tyrannosaurus Alan !
ooo... I like how the door and drive bay are intergated
. What make of ram is the XPS (hoping its not crappy unbranded stuff... but it wouldnt serprize me) -Frank
__________________
{Macbook Pro + Dell 2407 WFP - Canon 3000V + Canon 350D + BG-E3 + Sigma 10-20mm + 50mm f1.8 + kit 28-90mm EF - Rolleiflex 2.8 TLR}
*Flickr ~Flickriver ^ My Behance Art Folio |
#4 |
Multimodder
Dell needs to hire a wire wrangler or something, that is one of the messiest cases I have ever seen!
__________________
[size=1]AMD 64 6000+ X2, Asus M2N SLI Deluxe, 4 GBs of Corsair XMS 6400 ram, Nvidia GeForce 8800 GTS 320mb |
#5 |
Brett Thomas
Agreed that for the money, the finishing touches should be a bit nicer. Dell has always lacked those little 'extras', though, sad as that may be.
But a note...those clamshell cases? They used to use them on their earlier P4 and most of their Xeon server lines. Let me tell you, those things ROCK. I want to mod my current system into one (i have an old one kicking around), but the one I have is one PCI slot shy of ATX form factor. When you put rounded IDE or SATA in them, they become some of the nicest, easiest systems to work with. Everything's tool-less, everything's accessible, and for once...NOTHING is in the way of each other, even when everything is connected. I wish other companies sold them, or dell sold them as standard ATX cases separate from their machines. I'd buy one in a heartbeat, though I don't like the new door in front.The rest of the system, on the other hand, I can't say as I would touch for the life of me. Dell is renowned for putting BIOS locks on their boards that prevent OCing, and they may pre-OC the graphics cards, but that's just so you can't do it later. They warranty everything too much to risk letting the general public have control over the system, and though I can't blame them, I won't be running out and buying one, either. I hope, for all our sakes, that this nod to dell as a serious article is more of a "If you want to recommend your buddy a good gaming rig with a name he can trust..." Cost and components or no, Dell would be pushing the envelope to be considered seriously as an enthusiast system outside of laptops and servers (which you can't or won't do much to anyways).
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#6 |
Minimodder
I reckon that without much airflow in that case there will be an error message saying "A thermal event error has occured", within about 6 months. Much like the GX series seems to be suffering a lot of.
| scousechris |
| View Public Profile |
| Find More Posts by scousechris |
#7 |
SMP obsessive
Interesting, i wonder if they've got a sorted Nvidia Nf4 SLI chipset, the current one is extremely bug ridden and unstable.
__________________
i7 920 @ 4GHz 6GB Tracer 4870X2 || Dual Xeon X5340 @ 3GHz 12GB FBDIMM 4TB RAID5 w/27" Dell 2707WFP || Dual 1.6GHz LV Xeons @ 3.2GHz || Dual Athlon XP-M 2500+ @ 2350MHz || Dual Athlon MP2400+ || Dual Celeron 366 @ 550MHz |
#8 | |
Ultramodder
__________________
PC (Now out of use): Athlon 64 3000+ Winny | Asus A8N-SLI | 1024mb OCZ Premier | 6600GT 128mb | 160GB WD | NEC 3520 DVDRW | Coolermaster Centurion 530 | Hiper Type-R 480w Laptop: Dell Studio XPS 13 | Core 2 Duo P8600 2.4ghz | 4gb Ram | GeForce 9500M 256mb | 320gb 7200rpm | DVDRW | 13.3" LED WXGA |
#9 |
Lazy Lurker
On the contrary, thats pretty bog standard for a Dell of any variety inside, minus the two graphics cards. Id take a picture, but theres no camera for me to use at school.
__________________
Technology Schmecnology |
| RotoSequence |
| Find More Posts by RotoSequence |
#10 |
I Mod, Therefore I Own
we have one of those £99 dell servers they were selling a while back
it has the nicest sata cables i've ever come across, on par with the ones that came with my DFI NF4 board the DFI ones are excellent cos they lock in so damn tight, no way they're going to fall off the dell ones had nice 90 degree plugs on one end and locked in pretty tight too
#11 |
What's a Dremel?
Right, it's using SATA hard drives, it's just that they're hidden behind a green plastic cup type of thing for some reason. The floppy drive isn't fitted, but the cable is there, so it's just hanging around loose inside the case, hence some extra mess. And no, it doesn't really work that well.... Still waiting for that call from Dell tech support... in Texas!
#12 |
Why not? I own a domain to match.
Well my hatred of dell aside, it's pretty standard. You have to keep in mind that 99% of their buyers won't see that huge mess inside, and have a "as long as it works" mantra. Their $300 machine really can't be touched for price when you consider it includes a monitor, but anything much above that is a ripoff.
I bet you could overclock the thing with clockgen though, if you can find a compatible version. The most you'll be able to do in the BIOS is change the date, but that's standard dell if anything is (aside from making the PSU and case utterly proprietary).
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#13 |
Multimodder
I am currently running a dell dimension 8400 - 3.2ghz p4, 1gb ram, 6800gt gfx....my brother reconditions dell desktops and lappys and he gave this to me for nowt! I typically do not like dell pc's but I could not say no to this....previous spec was xp1800 with 512mb, fx4200....
Yeah, its a nice computer...plays hl2 very well....but the noise!!!! I hate to think what kind of racket the xps makes...... (because of the 6800gt card in the pc, bios keeps telling me to get another fancard...anyone know how to get rid of this annoying message @ post?) |
#14 |
Banned
It still just seems like a typical OEM to me, make the stuff you can write down as a feature first class, make everything as cheap as possible.
Case in point is the IDE cables, no enthusiast wants flats. The rest of the case looks messy too. OEM's like dell just won't put any love into a system, which is exactly what the thing needs before it can truly be classed as an enthusiast hardcore gamers machine. |
| specofdust |
| Find More Posts by specofdust |
#15 |
modding again!
For a Dell: its pretty damn good. For a dell. I mean: A DELL!!
![]() Anyway: here's a review of the Dell 600 too that I thought peeps may be interested in : ExtremeTech The cooler on the 7800GTX/GT's is far superior to the stock HSF setup on the GTX. Love the fact that (like the NV5) it pushed the air outta the case ![]() Pic of what I mean:
#16 |
Supermodder
DtD = Death to Dell.
__________________
Project Log: Knight Rider CWC |
#17 |
Minimodder
Yeah, I understand all that stompy, but, considering that the psu is sitting underneath the drives and with the door shut, there is a lot of heat on one side of the case, without sufficient cold air passing through the system stuff is going to get toasty in there... completely different machine granted, but out of 190 GX270's purchased less than six months ago in my place of work with a near as dammit door construction and minimum airflow setup 17 machines have developed a problem within the last three weeks, of which Dell have admitted a manufacturing problem with a capacitor on machines developed between Mar 04 and Apr 05.... and as an ex dell TSR I can say that for Dell to admit to a "Known Issue" is a big deal... This case although a tower with a few more fans does seem to be very similar to the layout of a GX270 .
Now couple that with two graphics cards which run well with decent cooling in a well ventilated case and I am sure, nay... adamant that this little B~stard of a powerhouse will cause no end of problems for anyone daring to run at full pelt for sustained periods of time. my very large 2p's |
| scousechris |
#18 |
True Jungle Brother
wow, what a pikey install.
surely now, even dell would have people who actually knew how to keep it tidy. afterall its not a low end spec machine |
#19 |
Mod Master
Dell. Change 1 letter and what does it spell?!?
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
| mattthegamer463 |
| Find More Posts by mattthegamer463 |
#20 | |
Lazy Lurker
That must be it! Bell! Similar to Packard Bell, the worst computer company in history! That MUST be the reference you were making
__________________
| RotoSequence |
| Thread Tools | |
