#1 |
Supermodder
how do i update Emachines bios
I have an emachines t1742 that is giving me some problems. First, i cant find the bios flash jumper. Second, I would like to get another bios for it so i can use the full capabilites of the motherboard and not have to see the emachines boot screen every time i start up. It is an intel celeron - like 1.7 ghz i think, and i am lookig for help
__________________
Current specs - AMD 2600+ Mobile - OC'd to 2.05 Ghz, 512 DDR 400, Zalman 7000Cu, a crappy NVidia 64mb video card, and an Abit NF7-S. Dual 200GB PATA drives, and dual 16x dual layer dvd burners |
#2 |
Network Techie
Mind posting what motherboard it is?
#3 |
Ultramodder
1) Sorry you have an eMachine. . .
2) eMachines product support is em, worthless- it does not say what type of motherboard is in you PC, nor do they supply a BIOS update. 3) Are you sure a BIOS update will unlock the "full capabilities" of your motherboard? Sure they've slapped on an annoying boot screen (I know Intel also does the same, I hate their boards. . .) but I doubt a BIOS would change much about your PC. 4) Every motherboard I have ever seen has had a jumper to clear the CMOS. If not, you can pull the battery on the board and clear the CMOS that way. I have not yet seen a motherboard with a jumper specifically for flashing the BIOS, instead you either have to download a utility and a BIOS file on a floppy and flash that way. There might also be options from within the BIOS to flash a update the BIOS. Good luck. L J
__________________
"Play a Windows CD backwards and hear satanic messages. Thats nothing, play it forwards and it installs Windows." |
#4 |
Supermodder
ok i am mistaken. I cannot find the jumper to clear the cmos. Also, emachines does not tell me what board i have, other than the fact that it is a trigem??? I am using Phoenix bios right now, and i havent found a way to get rid of the emachines boot screen. and yes, i too am sorry that i have an emachines, but it was free, and 1.7ghz was better than the 800mhz i had for doing school work. If anyone can find a manual, i have been unsuccessful, as emaichines support is "worthless"..
even if i am unsuccessful in updating the bios, can i possibly remove the emachines screen so i can sell the comp to someone without them knowing its an emachines - only the proc and mobo are original, i added new ram, hdd, dvd-rw etc. any help is appreciated Tim
__________________
#5 |
Ultramodder
Simply put, your going to have to search for some markings on the motherboard, that will identify the board. Otherwise, the odds of finding someone here with a manual for that PC are pretty low.
If the board is made by a company called "trigem" then I have never heard of such company and I doubt the board has much quality at all. I would upgrade the board to something farily cheap from a decent brand before selling the computer. L J
__________________
#6 |
Ecky thump
Moderator
You can get the latest T1742 mobo drivers from here, and the BIOS for a T1742 from AMI/Phoenix, but it will cost you $30. And it will still (I bet money) show the same boot screen. You can't just swap to any Phoenix 6.x BIOS, it has to fit the mobo hardware chips, so you need brand, model and revision.
With a popular board you'll find information on modded bioses and changing the ROM graphics, with an old cheapo odd-ball, fat chance,
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. |
#7 |
What's a Dremel?
mother board ID
pc-chips.com.tw made/makes emachines motherboards (pardon the 4 year delay
![]() http://www.pcchips.com.tw/PCCWebSite...nuID=0&LanID=2 |
#8 | ||
iPad Fan
__________________
"Not a bad day, this one! So far" - Richard Hammond as he steps out of a McLaren F1 and into a Bugatti Veyron.
| Tags |
windows ![]() |
| Thread Tools | |
