Reply
Thread Tools View Mode
Old 14th Oct 2009, 00:36   #481
Top Nurse
Hypermodder
Top Nurse's Avatar
Top Nurse has yet to learn the way of the Dremel
Originally Posted by Cheapskate View Post
OK...I'm starting to lose track of what all you have installed.
Yeah I was just noticing the same thing myself last night.
Hardware:
Lian-Li 2xxx black server case: forgot the name
Asus Crosshair III Formula motherboard
AMD 2.8 Ghz BE tri-core AM-3 CPU (OC to 3.4 Ghz)
GSkill 2 x 2 Gb PC ram chips
Asus HD4870 DK 1 Gb video card (OC to 850 mhz GPU & 1050 mhz ram)
WD Raptor 74 Gb drives x 3
WD 750 GB Black edition drive mounted into E-SATA enclosure
PCP&C 750 Silencer
Bulgin round lit switch (used for HD activity only. Switch does nothing)
Asus DVD SATA burner x 2
Dell S2009W monitor
Water Cooling:
Aquacomputer Cuplex XT silver CPU cooler
Aquacomputer Twinplex XT G 1/8 GPU cooler
Swiftech ram sinks to video card memory
Black Ice radiator 120mm for CPU circuit w/ Papst 1200 rpm fan
Silver Aquatube with black face plate for CPU circuit
Black Aquatube in front mounted Aquabay
Aquaero (GPU circuit) w/ stand-by power & relay used to turn on computer
Koolance 360 aluminum radiator (GPU circuit only) w/ three Scythe 2,000 RPM fans connected to Aquaero (typically runs around 800 rpm)
Aquastream pump (old style) for GPU circuit (mounted to rear of Aquabay)
Aquastream XT pump for CPU circuit
Innovatek flow meter for GPU circuit
Aquacomputer in-line water temp sensors x 2 (CPU and GPU circuits)
Koolance flow meter for CPU circuit inputted to Aquastream XT
Koolance 360 fan shroud
Oodles of plastic/metal Legris 8mm push-fits in straight, 45 & 90 degree
Aquacomputer Tubemeter in CPU circuit Aquatube
8mm black and clear (UV reactive) tubing
Software:
Multiple boot OS: XP Pro, Vista 32, Vista 64, and Windows 7 RC
Waiting for MS to ship Windows 7 upgrades in 32 & 64 bit flavors
Aquacomputer Aquasuite handles all the water cooling electronics
That's the major stuff, but not including the HD water circuitry. Yeah I know the water cooling is definitely over the top, but it has been a barrel of laughs trying to cram it all in this case. Can't wait to put in on the scales after it is all decked out.
Planned additions:
Silver Aquatube w/ black face plate for HD circuit including a Tubemeter
Aquastream XT for HD circuit
Aquadrive X4 copper edition HD cooler (fits four (4) HD's)
Koolance flow meter for HD circuit
Aquacomputer in-line water temp sensor for HD circuit
Independently controlled lighting for each of three (3) water cooling areas. Maybe an Aquacomputer Multiswitch
Cutting the case sides for windows and Feeding Frenzy name
__________________
H20 cooling: Go low and go slow
Why can't I just be a mundane and slog it out with the good stuff?
disturbed13: If its worth doing. Its worth over doing
Project: Feeding Frenzy
Top Nurse is offline   Reply With Quote
Old 14th Oct 2009, 08:02   #482
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
damn you got a lot crammed into that case lol.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 14th Oct 2009, 10:39   #483
jokkos
too busy to mod *sigh*
jokkos's Avatar
jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.
what he said. Still, it's nice to follow the progress and judging by the stuff you're going to add, it's only going to get more crammed
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 14th Oct 2009, 20:26   #484
Top Nurse
Hypermodder
Top Nurse's Avatar
I remember when I first bought the case and stuck a motherboard in it. I was amazed how much space there was in it and what I could possibly do to fill it up.
Forgot a couple of things in the planning department:
I intend to remove the fancy ROG heatsink sitting on top of the NB and will replace it with a waterblock. What kind of waterblock is where the indecision comes from. I have an original TwinPlex chipset block with a silver base that would go good with the silver Cuplex XT I already have. Or I may just use a standard copper TwinPlex XT I also have so that it matches the GPU & CPU water blocks. Or perhaps I might want to order up a silver TwinPlex XT.
The Black Ice 120mm radiator with a Papst fan has already been assembled for the HD circuit. Just waiting for some money to come in so I can get the X4 HD cooler on its way from Germany.
So many decisions and so many possibilities.
__________________
Old 14th Oct 2009, 20:51   #485
BlackWhizz
Supermodder
BlackWhizz has yet to learn the way of the Dremel
Estimated time when this pc is finished? :P
Soo many plans :P
__________________
Intel Q6600 - Asus P5Q-VM - Corsair TwinX 4x1GB - 8600GT - 640GB storage space - OCZ ModXStream 400w - Modded P180 Mini
BlackWhizz is offline   Reply With Quote
Old 14th Oct 2009, 23:22   #486
Top Nurse
Hypermodder
Top Nurse's Avatar
Soo many plans :P
Well considering I started this mod in July 27, 2005 any estimates of time might be not worth the paper it is written on. One of the problems is that my choice of water cooling equipment comes from about 1/2 way around the world and there are inevitable production and US Customs delays.
I am hoping to have this done by March 2010 or so, which will include the case side work and having the sides stripped and re-anodized in a matching black. That is of course assuming no more car crashes, trips to the OR or a nursing home.
Also forgot to mention that I am stripping off the ROG lit logo and replacing it with a little Aquacomputer logo.
__________________
Old 14th Oct 2009, 23:41   #487
disturbed13
Hypermodder
disturbed13's Avatar
disturbed13 has yet to learn the way of the Dremel
good god
i cant look away
__________________
If you think you can, then you CAN. If you think you cant, your RIGHT.
Originally Posted by jhanlon303 View Post
The modder in me says whack a hole, fool!
disturbed13 is offline   Reply With Quote
Old 15th Oct 2009, 05:50   #488
Top Nurse
Hypermodder
Top Nurse's Avatar
Originally Posted by disturbed13 View Post
good god
i cant look away
I say the same thing myself lately (btw, love your line about anything worth doing is worth over doing). A long time ago I sat down and roughly figured out all the money spent on this project which included oodles of tools, connectors, pins, fittings, etc. I got depressed, but this is a hobby so... more $ and more power!
This G Skill ram OC's pretty decent:
__________________
Old 15th Oct 2009, 06:39   #489
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Well said about money vs. hobby. You only live once. I mean, come on...really. THINK about it. You live ONCE. I say GO for it and go for it REALLY GOOD.
Anyway, having said that - you've been doing this mod since 2005???? I mean, I thought I was bad off having built my mod since spring 2008, but obviously I'm a quickie compared to you, haha. I guess your next mod (yeah, I said it!) will be better planned and much, much faster executed. Anyway, that's what I imagine in my head as to my next mod - will it ever come to be.
Nutman is offline   Reply With Quote
Old 16th Oct 2009, 00:26   #490
Top Nurse
Hypermodder
Top Nurse's Avatar
2005 with taking time off for a lot of work, another year for surgery, and IIRC there was also a major car crash along the way. I don't think my mods would go much faster than about a year. I first decide on a case and after buying it I just stare at it for a while mulling over the possibilities until I come up with a rough plan. Then it's pony up time and then hurry up and wait time.
I will be off line for a few days while I cook up some integrated hard drive and optical drive cables. Also got to paint up another flow meter and take apart the one that failed just to see what's inside.
__________________
Old 16th Oct 2009, 00:47   #491
disturbed13
Hypermodder
here! here!
__________________
Old 16th Oct 2009, 21:28   #492
Top Nurse
Hypermodder
Top Nurse's Avatar
Well it took considerably less time (about 6 hours) to get the hard and optical drive cables sleeved and in than the last time I did it. Got the back case side on for the first time in a long time. Pics probably tomorrow as I need to get it in the sunlight so you can see the real beauty of my insanity.
When I turned it back on I thought I had a major MB failure until I figured out I had forgotten to plug all the drives power in.
__________________
Old 17th Oct 2009, 02:59   #493
disturbed13
Hypermodder
too many things
too much to go wrong
but i love it non-the-less
keep it up
__________________
Old 17th Oct 2009, 20:30   #494
Top Nurse
Hypermodder
Top Nurse's Avatar
too many things
keep it up
What could possibly go wrong?
Actually that was why I used Aquacomputer control electronics and software because if the temps go up, the flow goes down, or the water levels drop then pop goes the weasel and humpty dumpty comes falling into a controlled shutdown.
Going out for a while to scrounge some modding supplies at the local Michael's and the surplus electronics shop. Sure glad I ordered in some DIY SATA power connectors a while back as they are hard to find locally and I think it is dikes time again.
Added: Sorry no pics today as we just had a big fog bank come in. The temps dropped back down to 70 F, but it is terribly humid too boot. No painting today either. So I guess I will rip my Aquaero out and do strange and wonderful things.
__________________
Old 19th Oct 2009, 21:24   #495
Top Nurse
Hypermodder
Top Nurse's Avatar
Well since we had another cloudy day I decided to just shoot some pics inside yesterday. Of course today is a nice sunny day with a few puffy white clouds.
First up here is that I decided to do something different on my hard drive data cables. I found in my junk pile some of my candy apple red cables. They really look nice so I figured why not show them off and do some black sleeving on it as well.
This was the initial mock up to see if it might work.
A side view.
I sleeved the SATA cables all in the same loom as it looks nicer and it is easier to do the routing of cables. The sleeving starts just a smidge back from the front of the hard drives coming out through the hard drive cage before making the trip up. Notice the evil red glint?
Here is the cut out for the HD cables and the USB cables are in the cut out above this. I also wanted the red cables to show through on the entry into the case for some symmetry.
Here are the SATA cables coming back inside the case and attaching to the MB header. I'm not going to take out my albatross flow meter until the other one is painted and sleeved. Please excuse the wire taking a jaunt across my case as I was doing some testing on the Aquaero start up wiring.
Next up is my infamous two for the price of one SATA optical drive sleeving.
Actually this cable is a temporary till I can find some more candy apple red cables that are a tad bit longer as I don't really like the way it traverses across the top of my middle floor.
One opportunity has arisen with the USB cabling as my case side doesn't close easily. More about this later when I decide what to do here. It's either combine the USB and HD case holes or make custom USB cables.
__________________
Old 20th Oct 2009, 17:09   #496
Top Nurse
Hypermodder
Top Nurse's Avatar
Has anyone ever re-wired their drive power looms with nothing but black wires and skipped the sleeving? Just curious as to how it might look.
__________________
Old 20th Oct 2009, 17:14   #497
Nutman
Nutman's Avatar
Hm, never seen it done in blue, but have a look at Project Flow (sniipe_dogg) - he's done the last 5-10 centimeters using only blue wires. But, mind you - his solution WILL drive you on the edge of madness!
Here's the link: http://forums.techpowerup.com/showth...=90726&page=10
Oh, and strive to get just NEAR his perfection, but stop in time before you're lost.
Old 20th Oct 2009, 22:09   #498
Top Nurse
Hypermodder
Top Nurse's Avatar
Hm, never seen it done in black, but have a look at Project Flow (sniipe_dogg) - he's done the last 5-10 centimeters using only blue wires.
Hmm... all red would look cool. Got to think about this a while.
__________________
Old 20th Oct 2009, 22:33   #499
drbo
Multimodder
drbo's Avatar
drbo has yet to learn the way of the Dremel
Just do it!
I think black could be cool, red a little bit over the top ....
drbo
YGPM
__________________
Project: DrBo's Dragon. A complete watercooled workstation.
Asus Crosshair III Formula (AMD 790FX/SB750) | AMD PII X6 1090T BE @4.1GHz |Sapphire HD5970OC | 4x 4GB Corsair DDR3-1800 | 4x OCZ Agility3 60GB SSD Raid0 | 2x Samsung 500GB Raid1 | 2x Samsung 500GB Raid0 |Corsair HX 1000W | LianLi PC-G70
drbo is offline   Reply With Quote
Old 21st Oct 2009, 06:12   #500
Top Nurse
Hypermodder
Top Nurse's Avatar
Originally Posted by drbo View Post
Just do it!
Yeah I think the black will be it, but then again there sure is a lot of black in this mod.
Now I need to fool around with the insulation displacing connectors or whether to just go for the crimp style connectors.
Forgot to mention that I put two (2) layers of green cellophane in my Aquaero VFD. I think I will need another layer to match my Aquatube color though.
Anyone had any experience in using green LED's in silver Aquatube's?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
