#1 |
Mod Master
Project: Digital Picture Frame- Oct 1 (Version 2.0!) Complete
Ok, i got this idea from a modding book my dad got me for christmas, and now i finally have the means to build it. Ive got a laptop, here are specs
P1 133mhz 32mb ram 1.4gb hard drive external cd rom heres what it looks normally like: ![]() heres a pic of it after i made it into a tablet pc, which is sort of the basis of the plan: ![]() so im going to get a picture frame and make a box around the back of it, then tweak the windows 95 and make it run better, and automaticly load the slideshows and stuff. more pics soon!
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W Last edited by mattthegamer463; 2nd Oct 2006 at 02:14. |
#2 |
Mod Master
Here is the discussion thread for my ongoing mini-project, making a digital picture frame, essentially a laptop behind a picture frame running a slideshow of pictures. Project log is below:
Project Log so have a look at that and tell me what you think so far. ill post some more pics of it when i get home, ill also see if i can get a pic of the frame im planning on using.
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
#3 |
Mod Master
Ok i scrounged up a image of what it will look similiar too.
picture frame pc click this link to go to the discussion thread: discussion thread
__________________
#4 |
I Mod, Therefore I Own
I've been wanting to do something similar for ages, will be watching
__________________
Steam: kev_fury http://www.youtube.com/user/furyksx - DFI x58 t3eh6 - i7-920 - XFX 6870 1GB - 6GB Patriot - - AstroGaming a40s - SteelSeries 7G - Razer Deathadder - 2209WA - |
#5 |
Chocolate computers galore!
Moderator
A fair few people have done this, but haven't posted a guide, I want one of these to put on a noticeboard, so will be watching! How are you planning to mount this onto a wall?
#6 | |
Mod Master
__________________
#7 |
Minimodder
Looking forward to seeing the final product.
Subscribed |
#8 |
Mod Master
ok, big update. Ive been working on the box that the parts go in, and its coming along quite well. heres a picture of the frame:
![]() and the backing for it: ![]() and the laptop in the right position with the screen spun around so that it fits into the frame: ![]() and heres the laptop inside the frame. ![]() the mouse in the picture hanging off the side will be in a hole cut in the frame. also, im going to buy a picture frame and glue it over the whole front of the frame, so it will look like a real picture frame, becasue it is a real frame. then to turn it on, to hook up a keyboard, or anything like that ill have to take the laptop out of the frame, which is very simple, and turn it on and put it back in running from battery until i plug it back in. this is only becasue the stupid slide on button cant be reached and i cant make a good way to turn it on. the mouse willb e stuck in the side of the frame, so only 2 buttons a and the ball on it will show, no circuitry. other than that, its finished! powerpoint automatically opens at startup, and it logs in automatically, all i have to do is click open presentation, select waht presentation, and click run show. then it goes for a day or so, and then i start it again. please comment in the discussion thread, a link to it is in the previous post.
__________________
#9 |
Mod Master
ok i posted a nice big update for you guys, so click here to see it. i made the frame for the laptop. now all i need is to drill some holes and get a picture frame.
__________________
#10 |
Mod Master
ok, ive continued working on this, and ive cut out the mouse spot that i am putting the mouse in on the side. now all thats left is to buy and glue on a picture frame. heres some pictures:
![]() ![]() ![]() ![]() ![]() the back is held on by an elastic stretched over 2 screws. ill screw on one of those things from the back of a picture frame with the little teeth that go on a nail for hanging it on a wall. then its a simple case of running slideshows on a loop. please post feedback on the discussion thread, a link to it is 2 posts up. thanks for reading!
__________________
#11 |
Multimodder
Do you think the power cable will reach it easily when its up on the wall? And won't it look slightly off having a power cable running down form a picture frame? Might be better off as a table top picture frame.
What kind of networknig capabilities does it have? If it can do wireless, you may be able to find some sort of slide show software that will just loop through all the pictures in a certain folder, then if you want to add new ones, you only have to log into the comptuer remotely and upload the pictures that way, you would never have to take it down to hook up a keyboard and such that way. And while your at it, maybe you could put a smoother running OS on it if your having problems with windows 95. Maybe a version of linux just running the bare necessities, those being the OS, the slideshow software and the networking software. |
#12 |
Mod Master
maybe, only problem is that a NIC card would create more wires, and a wireless card wont fit. also, im not really having trouble, except that i cant get more than 265 colour in 800 x 600 mode, so i dont think linux will help me there. i dont plan on updating the pictures very often, and when i do all im doing is pop the 'top out of the case, stick in a external cdrom, and transfer pics from a cdrw to the HDD in a premade powerpoint presentation. now, my only real problem is that if i loop the presentation i cant get out of it wihtout a keyboard to push escape on. unless you know of some slideshow software thatl let me stop the show with a mouse, i think ill have to keep setting presentations to show one pic per half hour, and after about a day restart it. it may get annoying, so ill probably bump it up to a few hours so itl run for a week or so and then ill restart it. if you know of some good slideshow software, please link me to it. my google scearches for software came up blank.
__________________
#13 |
Moderator
Well, if you use the windows slideshow and get a registry hack, you could change the timings to 1 hour or so!
#14 |
Modder
make a java script that counts down for an hour, then changes the registry so that the windows back ground changes? (im not good with java) or make a php that changes a picture after an hour or so and then maximise IE, that would require u putting php server on ur puter, which should be ok, its not exactly over taxing its self so far.....
Great idea tho, keep up the good work
#15 | ||
Mod Master
__________________
#16 | |
Moderator
EDIT: Maybe I should've looked at the specs first. W2000 might not run properly, you could try a severly cut down version of linux. |
#17 | |
Mod Master
__________________
#18 |
Mod Master
ok, nearing completion of this mod, it will be essentially done as of 3 to 4 days from now. I took the box to a craft store to see what frame would work best. simple task turned into a big task real fast. I ended up with this shadowbox.
![]() ![]() so im waiting for my custom matting to be made, then im going to put some L brackets on the sides of the shadowbox frame, and screw it to the main frame, then its all done! please post comments/suggestions/insults/threats on the discussion thread here .
__________________
#19 |
Wow - this is looking so good now!
Nice work
__________________
#20 | |
Mod Master
__________________
| Thread Tools | |
| View Mode | |
