Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Epox brings Socket 754 and SLI together
__________________
#2 |
Moderator
So we're going back to old technology?
Even so, I think its a fair idea for people not wanting to get rid of their processors. Saves you a fair bit I guess.
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors |
#3 |
Pewlius Caesar
bit-tech Staff
that's the idea - it is SLI for those who've not got a Socket 939 CPU and are considering the plump to PCI-Express/SLI
__________________
#4 | |
Hax.
pointless if you ask me. |
#5 |
Brett Thomas
I agree, webby.
I would want this...why? If you have a 754 processor, you'll already CPU limit any title that having SLI for would be a benefit...one PCIe 6800 and you're fine...Basically, if you're going to spend the money on all this stuff for SLI, why not upgrade your processor to something a bit bigger that offers dual channel ram? This is a lot like the "2 6600gt's in the same card" idea...
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo Last edited by Da Dego; 26th Sep 2005 at 21:31. |
#6 | |
Pewlius Caesar
bit-tech Staff
__________________
#7 |
Multimodder
****ing brilliant. I've got a 754 socket and, in my opinion, the fastest AGP card I can get. Now I can get a PCI-X GFX card with the option of going SLI and keep my CPU and RAM! Yuss!
There's a huge market for this I'd imagine, I'm surprised there hasn't been one released before. They're on to a winner with this board as far as I'm concerned.
__________________
|AMD FX-60||Gainward Bliss 8800GTS 640MB||SeaGate 160GB HDD / 2 x 320 GB SATA Seagate things I think ||OCZ Platinum 2 x 1GB PC3200 RAM|| MSI K8N Diamond Plus motherboard |
#8 | |
Pewlius Caesar
bit-tech Staff
__________________
#9 |
Moderator
bigz, "upgrade path" is the right word.
Basically you don't quite have the money to go the full blast to upgrade from an AGP S754 to PCI-e S939, so you take the mobo and graphics upgrade, then sometime in the future go for the mobo and processor upgrade. This would spread out the costs a bit, but in the long run will it actually save money? You would need a mobo compatible with both S754 to S939, which I don't see happening.
__________________
#10 |
Ultramodder
It make sense to those who don't want to take out a second mortgage to fund their computing addiction.
__________________
Top 5 Listening to Now - A Second To Last - Dying Against Your Will Rock Kills Kid - Paralyzed Zero State Reflex - I'm Splintering Hot Hot Heat - Middle of No Where ![]() - www.nerges.net |
#11 | |
Disgruntled kumquat
I just really hope that AOpen or someone comes out with a Pentium-M SLI (or Crossfire, I don't care) board. That would smash 3DMark records.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing. |
| Techno-Dann |
| View Public Profile |
| Find More Posts by Techno-Dann |
#12 |
Hater of Seagate
I'd like to see a converter for S754 to S939, that fits in a S939 board, personally. Surely that would be more logical? I highly doubt it would work though.
__________________
Lenovo 3000 N200 - C2D 1.6 - 2gb DDR533 - 120gb HD Xbox Live Gamertag: Sam00r | My Blog Type Thing
#13 |
Why not? I own a domain to match.
ACtually, the vanilla NF4 supports 754 and 939 to my understanding. It's just that manufacturers know it's a waste to invest time in making a 754 version considering it's lifespan.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#14 |
What is a Dremel!?
Moderator
I'm pretty sure that you're right. Foxconn made a Socket 754 motherboard that used nForce4 a while ago, IIRC.
Edit: The Foxconn NF4K8AB; that's the one.
__________________
"Nothing is more practical than a good theory" - Kurt Lewin |
#15 |
Ultramodder
ive got an 8npaj, the non sli version
has pci-e (hence why i got it) so i could use my x800xl, tbh, i like it, but im upgrading it to s939 soon, as its processor limited.... tbh, the cost of upgrading to s939 is so low it makes little/bugger all difference now... plus the raw power is alot better over 754.... |
#16 |
Multimodder
To me, this appears to be yet another niche motherboard. In reality, knowing how both SLi is largely pointless to get right off if you're getting anything less than the seriously high-end video cards, (I'd put the floor at perhaps the 7800GT right now, POSSIBLY making an exception for the 6800ultra in some situations) and also how the latest video cards have a tendency to be "bottlenecked" with anything less than a high-end Athlon64, (ANY Pentium 4, curiously enough, seems to not cut it in the most extreme cases, though hopefuly this is a fluke in benchmarks that doesn't translate in this case) you'd likely need to have an Athlon64 3700+, the max the socket will fit, right off the bat, and at that rate, and with you planning on going SLi, it really fails to make sense to get that motherboard, which will likely cost at least some $75US, as well as a pair of high-end nVidia cards, without giving your CPU some serious overhaul.
That said, there ARE some people who can benefit from this; those, for instance, who had a pair of 6800GTs from the previous generation, and looking to swap in a pair of 7800GTX 512s, while not letting their old cards go to waste, but know of a socket 754 machine that could use them. Also, people using a single PCI-e video card with their socket 754 machine, and looking to partake in SLi might be relieved to see that replacing their Athlon64 with what would likely be at least a 4000+ or X2-3800+ won't be necessary. It might even be viable for those with AGP, particularly in cases where you're looking to leap up from what is quickly becoming an outdated card like the GeForce 6600 to something truly powerful. |
| Nottheking |
| Find More Posts by Nottheking |
| Thread Tools | |
