RSS
Go Back   bit-tech.net Forums > Technology > Hardware
View Poll Results: What CPU for bit-tech's high end video card bench system?
Athlon 64 X2 4800+ 24 61.54%
Athlon 64 FX-57 15 38.46%
Voters: 39. You may not vote on this poll
Reply
Thread Tools
Old 2nd Oct 2005, 08:00   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
What CPU for bit-tech's video card bench system?
We've had a bit of a discussion here, regarding updating the specs of the new video card review system. I'm looking to overhaul the games that I use later this month too when a few of the new titles turn up.
I am looking to set up the following specs:
Athlon 64 X2 4800+ (or Athlon 64 FX-57)
DFI nF4-SLI DR (DFI SLI board) & DFI RDX200 CF-DR (DFI CrossFire board - I think... depending on how good it is)
2GB Memory (when its arranged/arrived)
Western Digital Raptor 74GB
OCZ PowerStream 520W PSU
16x LG DVD-ROM drive (don't need anything more)
plus whatever video cards land on my desk.
As for the mid-range system, I'll probably downclock the X2 4800+ to 2GHz to represent something reasonably close to the X2 3800+ (probably about 4000+ by my reckoning) and move down to 1GB memory.
What I want to know is - would you plump for an X2 over a single core CPU now if you were building a gaming system that you were also using every day? Obviously, the FX-57 has more single threaded CPU speed, but the X2 has the better all round performance by a considerable distance. I want this system to be as real as possible, so I'd like your help.
Basically, the budget is unlimited for a high end gaming system and the specs are pretty much finalised, with the exception of the CPU.
Vote and give me your thoughts on what we should be using. One thing we will not do for the time being is use a 3200+ and overclock it using an exotic cooling solution - overclocking is a lottery at the best of times, and I want a stock CPU that everyone can relate to. I've got both the X2 4800+ and FX-57 so the choice is between them. I can underclock them if you feel that is necessary, but I want to be as close as possible to a real CPU.
A reason why you chose what you chose would be really appreciated.
Thanks guys.
Tim S is offline   Reply With Quote
Old 2nd Oct 2005, 08:07   #2
chemo
True Jungle Brother
chemo's Avatar
chemo is on a distinguished road
well imho, id go with the fx57, as A, most people still have single threaded cpu's. and B, theres not many multi threaded games about yet. the change to dual core cpu's you use should be made later really, when its a bit more widespread.
chemo is offline   Reply With Quote
Old 2nd Oct 2005, 09:37   #3
Highland3r
I Mod, Therefore I Own
Highland3r is on a distinguished road
Tis a toughie. The FX would probably represent a more realistic gaming solution, having said that more people are starting to plump for multi-cored solutions.
As more and more games are moving to multithreading the X2 makes more sense. For single threaded games (ie 90% of the current crop) it probably wont make any difference. but with multi-threaded games, you run the risk of no longer being able to represent the "average Joes" machine.
Would suggest the FX is the best way to go for the moment, then as the multi threaded games emerge a possible more to Dual core? Maybe around the M2 launch would be a good time to make the switch perhaps?
__________________
Prawn or not...?
Highland3r is offline   Reply With Quote
Old 2nd Oct 2005, 10:24   #4
MrWillyWonka
Moderator
MrWillyWonka's Avatar
MrWillyWonka will become famous soon enough
I think you should wait a bit before going to X2, at the moment I think you'll get more "bandwidth" out of a single core processor than a dual core.
But is it possible for you to have both an FX57 and an X2 running for testing? That way you can compare performance on single and dual cores, which would be a good experiment on a multi threaded game.
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors
MrWillyWonka is offline   Reply With Quote
Old 2nd Oct 2005, 10:25   #5
Leeum
Mod Master
Leeum is on a distinguished road
I'd say the X2, seems alot more future proof imo
Leeum is offline   Reply With Quote
Old 2nd Oct 2005, 10:39   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Should I be testing mobos with X2s then?
Bindibadgi is offline   Reply With Quote
Old 2nd Oct 2005, 10:41   #7
chemo
True Jungle Brother
chemo's Avatar
yeah but its not about future proofing is it.
its about getting a easily comparable testing setup to give the average punter an idea of how games will perform on their hardware or very similar hardware anyways.
x2 is the future, but its just used enough to be needed in this rig just yet imho.
Old 2nd Oct 2005, 11:06   #8
Highland3r
Indeed, its about (from what I understand) showing how a card will perfom in an average setup, for the average user, as well as higher end kit. By using the X2, although you'll gain the futureproofing, its straying away from the "average joe"... For dual core games, you'll see an improvement, but chances are 90% of bit readers arent going to be running Dual core, so for them the review might be pointless, or give misleading information.
Stick with single core (even in multithreaded games) as (again from what I understand your reviews are meant to show) its not about which gfx card offers the best fps, but which offers the most playable or realistic settings for the average gamer out there....
If you're set on running the X2, at least pick up a lower end CPU to run along side, a 32000/3500 or similar would do tbh..
With both the FX and 4800 at full pelt, you'll get a good idea of the max performance, just think the FX will scale a little more realistically in terms of representing a mid and lower end systems.
If your set on the X2, maybe run SP2004/prime on the second core to represent a single cored system
__________________
Prawn or not...?
Old 2nd Oct 2005, 11:34   #9
hitman012
What is a Dremel!?
Moderator
hitman012 has a spectacular aura abouthitman012 has a spectacular aura abouthitman012 has a spectacular aura about
I think the X2 is more representative of what people looking for high-end systems will now buy. The FX is a superb processor, but I think gamers are looking more at something that will give them a better computing experience in general as well as good game performance.
__________________
"Nothing is more practical than a good theory"
- Kurt Lewin
hitman012 is offline   Reply With Quote
Old 2nd Oct 2005, 18:36   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
With the way that we do motherboard reviews at the moment, I don't think it is mission critical to use dual core CPUs right now. However, FWIW, dual core CPUs are definitely taking off and it is the way forwards.
Old 2nd Oct 2005, 18:46   #11
RotoSequence
Lazy Lurker
RotoSequence's Avatar
RotoSequence is on a distinguished road
This is definitely a tough one to call at the moment. At this time, the nature of games is that they are single threaded. The environment for something like 99.9% of the users on bit-tech is single threaded (discounting Hyperthreading CPUs). A more accurate representation for a high end system right now is that of the uber single threaded processor, yet, more and more users are shelling out for an Athlon 64 X2; in fact, high end computers from Gateway are starting to come equipped with dual core processors (Pentium Ds and X2s). If you have the time, you could always do both. However, I only know of one person who has recently bought an FX, but I do know of a few more who have gotten the X2.
The brand new high end rig right now has the X2 4800+; the past one has the FX-55 (or possibly the 57). I suppose the ultimate representation of today's ultimate gaming machine would have to be through the FX-57. The Ultimate system however, would be one with an X2 4800+.
__________________
Technology Schmecnology
Last edited by RotoSequence; 2nd Oct 2005 at 19:14. Reason: Edited to account for Pookey ;)
RotoSequence is offline   Reply With Quote
Old 2nd Oct 2005, 18:58   #12
Pookeyhead
It's Big, and It's Clever
Pookeyhead's Avatar
Pookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to allPookeyhead is a name known to all
Until games that support dual cores become the norm, it makes sense to use single core chips IMO, or perhaps bench cards in both to show a balanced view. At the moment, the FX57 is the fastest gaming platform, and probably will continue to be so until more titles appear for multi-cores. (and no im not just saying that because I have one... that's WHY i got one).
I still think you shoudl bench both, as both chips will be at the forefront of high end gaming systems for a while yet.
__________________
Intel i7 920 @ 3.8GHz ¦¦ Asus P6T Deluxe ¦¦ 6Gb Corsair Dominator C8 ¦¦ XFX GTX295 ¦¦ 2x 1Tb Samsung F1 ¦¦ 1x Seagate 7200.11 1.5Tb ¦¦ Gigabyte Odin 800W PSU ¦¦ Dell 2405FPW.
Pookeyhead is online now   Reply With Quote
Old 2nd Oct 2005, 19:02   #13
Pookeyhead
Pookeyhead's Avatar
Originally Posted by RotoSequence
I dont know of anyone on bit-tech who has actually bought an FX recently, but I do know of a few who have gotten the X2.
ahem....!!!
__________________
Old 2nd Oct 2005, 19:08   #14
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
It depends how often you fancy getting reviews!
YES, I agree it would be awesome to be able to provide you guys with a video card review that uses both single and dual core CPUs, but that just isn't practical from the time required vs. page views returned perspective. Thus unfortunately, it has to be one or the other.
I am, however, looking to increase the number of games we use a little to provide a more rounded look at the card. I want to include an RTS (and maybe an MMO) as well.
Old 2nd Oct 2005, 19:12   #15
hitman012
What is a Dremel!?
Moderator
I think the problem is differentiating between a high-end PC and a high-end gaming PC. It really depends what demographic you're trying to represent - someone who's just bought a top-spec computer for general use and gaming, or a hardcore gamer who has purchased the FX specifically for its performance in games.
The high-end system is obviously a lot more common and representative of many more people who would buy a PC than those who get one just for gaming. That's why I think the X2 should be used for the benchies
__________________
- Kurt Lewin
Old 2nd Oct 2005, 19:21   #16
Pookeyhead
Pookeyhead's Avatar
I suppose you have a point... it's just that hardly any games use the X2.. that's all I was thinking. It's all about what PCs are actually OUT there... rather than ask "what spec should we bench with"... you should ask "What PCs do you HAVE"? If you're trying to represent Mr Average with a high end PC that's used for many things, then lets see what Mr Average actually owns. Personally, I'm not bothered myself, as I'll just Ebay this FX when games start to appear that support X2, as I can drop one straight in this MoBo no problem, I'm just worried you're basing it one what you think you should be doing cos multi cores are the future.... (yes, I realise this even tho I've just bought a FX... I've given up on being future proof... future proof and PCs? No such thing).... instead of basing it on what people actually own.
__________________
Old 2nd Oct 2005, 19:34   #17
TheMuffinMan
Supermodder
TheMuffinMan's Avatar
TheMuffinMan is on a distinguished road
I would have to go dual-core, just for future proofing, I just spec'd out a system that was roughly $2000 USD with a 4800+, 7800GTX, 2 gb Ballistx, the Newegg sale on 74 gb Raptors , Sony DVD+/-RW, and a DFI mobo. I dont think $2000 USD is that far out of the reach of most users on these forums, and that's almost top of the line equipment at this moment, I would imagine you could pick up like a 4400+ and drop the price below 2k easily.
TheMuffinMan is offline   Reply With Quote
Old 2nd Oct 2005, 20:00   #18
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Amen to that. Do AMD still advertise the FX as the fastest gaming processor?
Old 2nd Oct 2005, 20:10   #19
RotoSequence
Lazy Lurker
Originally Posted by AMD
  • The first 64-bit PC Processor, in a class by itself, designed specifically for gaming.
  • Enthusiast-friendly, enabling gamers to discover the true potential of their PC
I'd say they do.
__________________
Old 2nd Oct 2005, 20:11   #20
specofdust
Banned
specofdust's Avatar
specofdust has a spectacular aura aboutspecofdust has a spectacular aura about
Having taken part in that discussion my opinion is thus:
If this rig is designed to make sure it doesn't limit the graphics card at all, then an FX57 should be used.
But if the rigs being designed to show people how a graphics card will probably act in their system, and X2 should be used instead, since more people are going to be buying X2's now.
Voted FX57 though, due to the title
specofdust is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
