#1 |
VX mad
New at networking
Right i'm not completly new at netowrking but not up in the leagues of netowrk admins and so forth.
The problem is this: - 3 Computers (names: Dads, Lola and Jenna) Lola and Jenna running XP Dads running Me Lola and Dads can see each other on the network Jenna is not viewable, although sometimes you can see it but not browseable The plot thickens: Dads is running ICS and Jenna and Lola can both browse the net when Dads is connected. All computers are connected through a Genius 10/100 8-port hub. Dads = port 1 Jenna = port 2 Lola = port 3 i'm pretty sure this diesn't make a differance. So I need to get Lola and Dads seeing Jenna. Also they can all play network games except ones that require a IP address. Any help is gratfully acepted.
__________________
:[M3N-HT Deluxe/HDMI]:[AMD64 Dual Core 6000]:[2gb Corsier PC8000]:[3x6800GT 256mb @ 19" VX912 & 2xVP920 & 15"LCD 13" ELO TouchScreen & 17" CRT]::[nVidia 780a @ 17"CRT & 100" HD Projector]:[3xMaxtor 250gb]:[3xMaxtor 250gb]:[3xNEC 16xDVD-RW]:[16x 5Disc Mulitchanger]::[2xSeagate 200gb-100mb-NAS+4xHitachi 1TB-1gb-NAS +4xHitachi 1TB-1gb-NAS]::[4xSeagate 500gb-FILESSERVER-Dual Gigabit]:
#2 |
Nobody but us chickens
First off make sure you can ping the machine?, if not then its most likely problem with tcp/ip which will need sorting.
Make sure you have file and print sharing on the ME version, if it is goto an win xp box then start->search->computers or people->computer on network->the ME machine name. If it finds it and you can access the share then its just taken time to announce itself. Also check that your not using a personal firewall that may be blocking the broadcast.
__________________
A police recruit was asked during the exam, "What would you do if you had to arrest your own mother?" He said, "Call for backup." "you could have it all, my empire of dirt, I will let you down, I will make you hurt" |
#3 |
Supermodder
make sure ther on the SAME WORKGROUP
that will more than likley be the problem, tho another obvious problem is you have a copy of ME. (Many Errors) on a PC you own NUKE IT ![]() XP or 2k own
__________________
gone with puff |
#4 |
VX mad
I can ping 'dads' but it can not view it on the network. All the computers are on the same WORKGROUP. GJUK what do you mean by a 'copy' of ME. I of course support MS fully!
__________________
#5 |
Supermodder
copy, intallation. same thing. im not proposing you have ilegal copies of any software, or that you should use them
where the hel did i state that ? some ppl
__________________
gone with puff |
#6 | |
VX mad
__________________
#7 |
Ultramodder
are you suggesting that the 'original version' you have is
a) The only one ever made ? b) different to all the others in some way ? what is the definition of a copy.... i think any windows CD counts, be it a pressed MS original or a copyright infringing CD-R. |
#8 |
VX mad
OK OK!
Can we get of the subject of what is meant by 'COPY'. I obiviously don't have hte only ME CD made. There of course was millions of them. Just the fact GJUK stated that the 'copy' I had may contain errors (which most CD-R copies may well do). Can someone please help me with my problem. I don't think it lays in the ME machine as that machine sees my second XP machine (Lola). Jenna (my first XP machine) is not viewalbe or accessable on the network. But yet ICS runs via Dads (ME machine) and accesible by all. That solves whether it is on the same workgroup problem (which I know they are).
__________________
#9 | |
Supermodder
![]() i mean you might wanna try XP on you machine, then if it works invest in the original ? worth a try if you dont get anywhere... maybe i mean i HATE M.E. it sux imho
__________________
gone with puff |
#10 |
VX mad
Cheers for that GJUK. One more thing I have the original!
I don't think XP will work on 'Dads' its olny a P200 with 128mb EDO-RAM. Best not to chance it.
__________________
#11 |
Supermodder
np man, maybe win 2k might work, ?
'avva play
__________________
gone with puff |
#12 | |
inter arma silent leges
Moderator
cables connected? = obvious way of checking. link estabilished? (lights on hub/switch) = as obvious as above. TCP/IP working? (machines can be pinged and have been assigned an IP) = One way of testing the TCP/IP setup is to statically assign the IP address to all three computers, do one as 192.168.1.1 , one as 192.168.1.2 and the other as 192.168.1.3 and then try and ping from one computer to the other and then vice versa. Ensure all PC are in the same subnet. All machines share the same workgroup? = Check for spellings Drives have been shared? = check drive properties. this is not a complete list of all possible variables but you get the idea. One issue could be XP's "wonderful" inbuilt firewall Go to Network places > properties and then to the properties of your LAN connection. Click the advanced tab. Under Internet Connection Firewall, Uncheck "Protect my computer..." and try again. If this solves it one of the firewall settings is too strict. here is a link to one of the best IMHO Windows XP networking help sites Practically Networked XP Help
__________________
"Flying is simple; push on the stick and the houses become bigger, pull back on the stick and houses become smaller, unless you keep pulling in which case the houses will become bigger again..." |
#13 |
VX mad
I'll check um all again. Cheers for that advice.
__________________
#14 |
Spaceman Spiff
dont use ME....use win2k...sorted...
__________________
...wordEs...
#15 | |
Supermodder
but NOOOOO
__________________
gone with puff |
#16 | |
Spaceman Spiff
__________________
...wordEs...
#17 |
Ultramodder
u can change ur ip on ur dads machine goto home tcp/ip for the network and change it then make sure there on the same workgroup and then change the ips on the other computers
10.10.10.1 - 3 thats the most simple 1 out or u could do this most used 1 in these forums 192.168.1/or0.1 - 3 |
| Tags |
| network |
| Thread Tools | |
