Prometheus
My 3D printer project
Sea Shadow
Prometheus
Not the best soldering job, but not bad considering it was done with a junk iron.
27 Sep 2010
Sea Shadow
Prometheus
The sockets make it easy to replace the drivers, should I ever manage to burn one out or need to replace it.
27 Sep 2010
Sea Shadow
Prometheus
4 pin Molex connector
27 Sep 2010
Sea Shadow
Prometheus
4 pin Molex connector for power (12v for the motors, and 5v for the IC logic.
27 Sep 2010
Sea Shadow
Prometheus
The strip of pins down the right side are the enable/step/direction control lines for each driver chip.
27 Sep 2010
Sea Shadow
Prometheus
The header in the top right is for the minimum and maximum endstops for the axes.
27 Sep 2010
Sea Shadow
Prometheus
These headers are for the motor drive lines.
27 Sep 2010
Sea Shadow
Prometheus
These are pull up resistors to define the stepping configuration of the driver chips (in this case 1/16th micro-stepping).
27 Sep 2010
Sea Shadow
Prometheus
I almost started with the tall parts on the board, whoops.
27 Sep 2010
Sea Shadow
30 Jul 2010
Page 12 of 27
11
12
13
14
27
