Prometheus
My 3D printer project
Sea Shadow
Prometheus
Small flats were ground on the shafts of each motor to give the bolt something to stick to
04 Sep 2010
Sea Shadow
Prometheus
Each of the gears has a trapped nut to hold the gear in place
04 Sep 2010
Sea Shadow
Prometheus
Nema 17 1.8 degree stepper motors
04 Sep 2010
Sea Shadow
Prometheus
I have added the lead screws for the Z-axis and installed the X-axis (it was upside-down when I took the picture)
03 Sep 2010
Sea Shadow
Prometheus
Time to square up the each axis and add some loctite
03 Sep 2010
Sea Shadow
Prometheus
All bottom rails have been installed
03 Sep 2010
Sea Shadow
Prometheus
Alternate view
03 Sep 2010
Sea Shadow
Prometheus
Now some of the center supports have been added, they are needed since the Z-axis belt will be tensioned right over that area.
03 Sep 2010
Sea Shadow
Prometheus
The back rails have been added. If you look closely you can see where the motor for the Y-axis has been mounted.
03 Sep 2010
Sea Shadow
30 Jul 2010
Page 18 of 27
17
18
19
20
27
