Prometheus
My 3D printer project
Sea Shadow
Prometheus
Bearings keep everything rolling smoothly
05 Sep 2010
Sea Shadow
Prometheus
Assembling the pieces together
19 Aug 2010
Sea Shadow
Prometheus
The large mudguard/fender washers function as guides for the belt that will be running over the bearings (under the washers)
03 Aug 2010
Sea Shadow
Prometheus
Almost done with the assembly
03 Aug 2010
Sea Shadow
Prometheus
They will be used to hold the corners in place and keep the enclosure top from sliding around.
22 Apr 2011
Sea Shadow
Prometheus
I am using my laptop to generate and stream G-code to the printer. I will have to slap together an old computer for the task later on.
06 Feb 2011
Sea Shadow
Prometheus
My A-frames only had 2 support clips, and I needed 4. That's easy enough to fix.
06 Feb 2011
Sea Shadow
Prometheus
This picture was taken after a few trial runs, the yellow plastic is some print material that fell down inside and I haven't bothered to take apart th
05 Feb 2011
Sea Shadow
Prometheus
The scorch marks are from a lighter that I used to soften the plastic.
05 Feb 2011
Sea Shadow
30 Jul 2010
Page 19 of 27
18
19
20
21
27
