seems far too pricey for me...
just another vote that you go to a central place and use a patch panel. Also, make sure you buy enough cable to slack at each end incase you need...
exactly what I would suggest too, and i'm a network guy! just bare in mind warranty status which you won't get with pfsense (except hardware...
done! </retard_moment>
:blush: :wallbash::wallbash: i cant change a thread title can i?
http://www.reddit.com/r/buildapc/comments/1rhmxu/what_is_the_major_differance_between_intel_and_amd/cdnd7jn
amazing! is it particularly heavy? how have you found the battery so far?
Sorry to go slightly off topic, but this thread has just convinced me to go and buy a Play1 tomorrow! Am i right that if i use the wired...
point taken about shifting the responsibility. i guess it depends on what kind of backup you have from where you work. one of the reasons we...
it depends on what services you want to use. lots of it just needs the controller to set things up. if you want captive portal then you will...
i'm not so worried about paying, so long as it is a really high res screen. i should have mentioned before, i'm not looking for bigger screen...
I'm fairly sure the Ubiquiti UniFi Pro ticks your boxes. I use this distributor and they will know for sure and are very helpful on the phone:...
try calling your ISP, but they quite likely tell you there is no problem. try setting your DNS settings on your computer to Google or OpenDNS and...
agreed with all of the above, the wiring in your house will have a massive impact on their performance. some have a built in wireless access...
echo what everyone else says, with a 100mb connection - your bottlekneck is nearly always going to be the wireless. if this is your only option,...
i used to supply those routers to all my clients, but stopped a while back as they proved quite unreliable in the long run. i would suggest using...
besides the top top end laptops, and the Macbooks with retina screens, why are there so few laptops with full HD screens - especially as a Galaxy...
cheers, will check them out. PS: excellent avatar
case size no big issue. only going to have the essentials i.e. mobo, psu, dvd and a couple of network cards.
Hi All, Am building a NAS that will be holding at least 6 drives. My primary requirements (beside having bays) is good cooling and cost....
