Well if it stays with that price then... I don't think many people will buy one no matter how good and ncie looking it is... But I am sure Nvidia...
The price is way too high for that configuration but that is because alienware branding. :D I would suggest to avoid it... But if you have Xtra...
I don't know why you hesitate to buy 22 inch monitor? It is perfect for using and it is far from too big. Maybe you will think that way for the...
GTX 280 if you have some cash to spend but otherwise go for ATI 4870 with OC ofc...
My friend have that Samsung monitor and he is satisfied with it. He did not have any problems so far. And for more detailed review and info watch...
I think you should have posted poll so you can see the results and decide yourself but since you ask, I think you should get CPU, your GPU isn't...
I can't wait to get one of the new models. I think I'll have Macbook Pro and reason more is that Apple changed to Nvidia chipsets... That's cool...
I think it isn't possible to install them on the same partition. Because for example, if you try to install XP on partition that already has Vista...
I think you should surely get it... That price... is priceless :D Use it wisely.
Nvidia will pwn ATI in either way...
I think it's time for some 9800GT maybe? :D
Isn't that kind of too strong for 1000 euro budget? I mean just 2x 9800GT will cost half budget :)
I use USB port just for flash memory, and I use Headphones port often too...
I think these things cost about 40000-60000$, At least Microsoft and Cray agreed so that these computers will have special Microsoft operating...
I couldn't agree more... I had same situation like this... And I wasn't satisfied with GPS phones, SatNav is cool though, and phone separately :D
I think Kaspersky is surely the best for protection (price is high though) but kind of slows down system a little... On the other side, there is...
And for RAM I would recommend you GEIL... They are great and not so expensive.
And I almost got scared for the moment... :)
100% agreed - Ipod is for those who use Itunes... Zune is cooler :D
Well, I don't think that you will use three way SLI's maximum potential if you get it. At least not at this moment. But it is surely better...
