Which version are you running? Anyways to get on a sub-team you just have to change your folding username to Spider_Monkey and then youll be...
Project Aurora mini poll 19th December Could you possibly polish/buff that plexiglass? Ive seen a similar project that used glass-clear plexi,...
Aspire One PXE MOF Exiting INTEL PXE ROM NO OS Found Help I had Win2k installed for a short period of time. I used external CD-ROM during...
Hey Darren , I finally got my dv cable and have downloaded video but when I try to upload it says I have exceeded the limit of KB Im using...
Went to see The Who exhibition a couple of weeks back. Same exhibition that was at Clerkenwell Green a few years back but still worth seeing....
Razer : It seems that the 8800GTX is the daddy long legs of the range and I read on some forum that it needs 280mm of space to fit. 8800GTSs are...
"W" is for Water December 16 The birth of a reservoir On the s&w cages it seems they only have a 2dr cage... i dont know how much the cars differ...
"All of this could have ing been prevented if I had just brought my goddamn pee bottles" or if you had taken a st in a public toilet... "WTF?? The...
Batman Arkham Asylum 2 announced Hi guys reformatted and backup everything yesterday. Problem is batman arkham asylum either refuses to recognise...
Hey all. I need some help finding mic stands similar to the ones used by radio stations. A friend suggested that I use lamps from walfart and...
Dont go ATI for a folding rig dude. Nvidia cards EASILY best that. Same with AMD processors. I would get a Q8200 on a cheap P45 board and get 2...
Aspire One PXE MOF Exiting INTEL PXE ROM NO OS Found Help I have a aspire acer one a150 with linux i have had for sometime now,not really used it...
Crysis Did you upgrade Like the topic saise, What do you think about the game? Me, well, i like it allot Didnt think the MP would as fun...
Saboteur PC doesnt work with ATI I had a similar problem with PS3MS when I updated java, although it was a while ago with a different version of...
Ok, i have a question regarding DVI. There are several types of DVI: - DVI-I - DVI-D - DVI-A i think as well - Dual Link and Single Link...
