Also 780ti Lightening, HOF and Classy will be much fun too!! as R290X Lightening. All of these cards will actually fulfill your needs well. The...
7970 is the only card to have at £200. Absolute bargain.
I have four 290X they are benching great so far in 11, Vantage, Heaven, FS and FSX. As drivers mature so are the cards with each revision. With...
124 is usually Vcore, or VTT / IMC volts. These can be both too high or too low so you need to test.
This is high already for 4.5 on 2500K Try 1.375 and so on up in small steps. If you cant get it stable back off to 4.4 and retest.
Dont worry about the ASUS board double booting from a full system power down. Its going through memory training which means its testing...
Temps are high for sure. You tried cleaning out the fans attacehed to your cooler to make sure of good air flow and obviously re-seating the...
101 in the mix the is Vcore for sure!! Add some and see how that goes. Another option is to raise LLC to give higher mare stable core volts under...
EIST is actually a good idea with SB, C states is not. As far as your system goes I would also Memtest first but also check the BSOD codes...
I would try the sticks first at XMP, 2T command rate with 1.65v check the lower timings though as these may be too tight for stability. If this...
