Despite their developer walk-through explaining that virtually every wheel under the sun would work, I couldn't get my Driving Force GT to work...
Good news from the previews released today. Some key points: Dirt 3 has the WRC license. Toned down the menus to still be stylized but more...
It appears the Codemasters devs are doing damage control posting on various game forums that they have greatly toned down the "Xtreme" aspect and...
I replaced the seals and one looked just a bit off, almost like it wasn't a consistent diameter all the way around. After I finished I set the sag...
I have a seal kit coming my way soon. I think it must be the issue because I seem to get the sag set perfectly at 25% and then after my ride it is...
Anyone have any experience with the Fox Float R rear shock? It came standard on a bike whose other components were too good to pass up. I cannot...
Any chance you could comment on the mechanics and performance of split-screen on the PC version? I'm curious how well an i5 750 and gtx 260 216...
My asus bios pops up as per normal then it goes to my partition selection screen(this has always happened only flashes for a second) Then the 7...
Today I bought Toca Race driver 3 from the steam sale and it installed without a hitch, however when I went to play it Star Force popped up saying...
I finally emailed EA for help and their response was the only weapon that should be bugged is the assault's AUG, the others he said sounded like a...
Anyone elses weapon stars incorrectly unlocking? I have over 100+ kills with certain weapons but no stars, when they finally do show up it will...
Black cranks and red anodized pedals would complete the look.
So how are the controls on consoles? I was planning on getting this for PC but after hearing about the new DRM scheme it will use there is no way...
Use nHancer, if you have the steam version of Bioshock 2 or Mass Effect 2 make sure to create a new profile point it at the .exe in the binaries...
Small dorm room and I never even hear my Haf 922, I haven't messed around with an aftermarket cooler yet though.
I have a weird issue. I just finished buying and building an enthusiast overclocker build. Everything has been working great except I have one...
I'm in the same boat, been looking for a 5850 but I can't find any place that has them let alone ones that aren't marked up 100+ dollars from the...
That was partially my first question. If the 80gb is the boot drive will Windows 7 recognize the files on the 750gb drive? I'm mostly worried that...
Okay so my plan so far is this, create a new partition on the 750 drive and move the game installers/movies to this partition, then wipe the 80gb...
I'm planning a new build soon and I had some quick questions about hard drives. My current computer has an 80GB HD and a 750GB HD both formatted...
