Well, first time I've thought to login to these forums in a billion years -- thought I best put my PC to use while I'm sat here next to it, on a...
If only we could all just spade a bit of sand out of the way to lay new fibre. :rollingeyes:
Why the hell am I buying this game AND having to pay for it in advertising? GTFO.
What happened to competitions that didn't involve selling all your personal contact details without option? Oh wait, that's right; Dennis.
The Raptors are 10K RPM SATA disks. To my knowledge, there are no 15K RPM SATA disks. They're also not SAS, which matters greatly under certain...
No, they'll continue to eek as much out of their DOCSIS investment as possible without digging up the streets again to run FTTP. Of course...
That's what I thought. Wikipedia appears to agree. Sam: it's only a showcase. They still won't be able to provide a proper service because...
His plane already has the tail number 'G-OCOK'... http://www.abpic.co.uk/search.php?q=G-OCOK&u=reg
Not that I mentioned it earlier, but the RAM is sorted. The machine's already running very well with 2x4GB G.Skill Sniper (1.25V, DDR3-1600)....
Except when their ports to LINX are congested/dropping packets. And not to mention their policies on net neutrality which may one day see them...
Nonsense, it's not an island!
I'm currently looking at picking-up a new case. My recent build is currently looking like this: i5 2500K, aboard the Gigabyte P67-UD4-B3 Be...
As many have said, Power-over-Ethernet just requires a Cat5e cable, with all 8 cores available. For the most part, this limits you to 100Mbit...
Gunstar Heroes! Awesome.
I think the biggest problem here is that they generally aren't 'cheap'. I may be biased, as my research is limited to Dual DVB-S2 models that...
I am finding it difficult to imagine Sci-Fi from Blizzard that isn't set in the Starcraft universe even a little bit.
Any kind of filtering could potentially have an impact, but in general, the cheaper the extension socket the better it's likely to be for...
How do you know they're not able to sniff the traffic anyway? Have you been around there and tested? ;) One more reason why you should be using...
Yes, 40Gbit and 100Gbit Ethernet are now 'available', too. And if you go back a bit further, Infiniband (which is similar to PCI Express in a...
No really, you wasted an entire post on that? You could at least elaborate. Or was this intentionally an ambiguous quip to support the presumption...
