I have a cheap MP3 player that uses the WM8759 DAC, and I wonder if it's possible to somehow convert the signal to a format that can be sent to a...
http://www.zellestyle.com/catalog/1337.html It'd be interesting if we could somehow ask for dud parts (that do not work right but look fine) from...
I tried putting OpenWRT (squashfs) on my Belkin F5D7230-4 (v1444), and it doesn't work. Can anyone help? Below is what the text terminal shows:...
I got the PCM2902 USB audio chip working (the USB interface at least), but I have some questions. For the S/PDIF input (coax), should the receive...
http://ktechlab.org/ Enjoy! I'll try it out on my Athlon 64 running Debian 3.1.
http://shop3.outpost.com/product/4575027?site=sr:SEARCH:MAIN_RSLT_PG Is that one any good? I noticed that it uses a metal tip, instead of the...
Is there a driver that allows me to use my sound card to decode audio from an AIW 9000? My sound card doesn't have a S/PDIF input and I want...
How do I use a 16C550C to interface a serial port to a homemade logic circuit? Any example circuits?
Where can I buy a CDP6402 or compatible UART in the US? Is there a chip available from Digi-Key that's compatible? (It does not need to be pinout...
I'm trying to build an alarm clock that plays music (just one song is enough) and I need to load the song onto the old MP3 player that I'm going...
http://www.ananova.com/news/story/sm_1570835.html?menu=news.quirkies Just imagine the possiblities... And if Intel chips are used, that gives...
http://www.say-no.se/ It is time for all music and movie lovers to put their foot down and SAY NO to high prices and lack of quality online...
Here's the PC-based version! http://www.gnu.org/software/gnuradio/ Would it be possible to use a video capture card as the ADC? Or use a HDTV...
Is it possible to modify a flyback transformer with an integrated rectifier to output negative voltage instead of positive? It's for a negative...
http://www.bluesecurity.com/ I just participated in that project. Let's join in and help fight spam! BTW, continue running your other...
This idea suddenly came to me: what if an expansion engine is used instead of a TXV in a phase change system? I see that it would improve cooling...
Does anyone have a good design for an electrostatic air cleaner? I've taken a look at some Sharper Image units but they're way overpriced, so I'd...
I've recently replaced my central A/C system and now ended up with some motor run capacitors from the old A/C. (I tried to salvage the relay, but...
http://www.artlebedev.com/portfolio/optimus/ Pretty interesting. It'd also be funny if someone made a program that displays a Britney Spears...
http://camerahacks.10.forumer.com/index.php Has anyone already modded a CVS disposable video camera? BTW, my camera has firmware version 3.4 and...
