Hey there, My MSU mail account is going away in 2 days as I didn't graduate there and I haven't attended classes in 2 years... so I will be...
An 805 can be a pretty decent processor, I've got a rig running one now, shown here: CPU-Z Database. For the price, I'd definitely recommend it;...
So I installed Windows XP on a new machine that I just built, an 805 with a P5WD2-E Premium motherboard. I was getting 2 issues every time that I...
Does anyone have experience with an ECS C19-A SLI motherboard? I've read a bunch of good reviews... I purchased an 805 Smithfield from Newegg,...
I mixed up a 15% Dexcool/85% distilled water mix to run in my loop. I did a test run of the system, and noticed that the coolant seems to leave a...
I bought a Maze4 chipset block, intending it to go on an A8R32, but it physically doesn't fit. Are the holes the same placement/distance as the...
Ok guys, quick question. A few weeks ago I saw a site out there somewhere that had plans for implementing diodes into a relay so there couldn't...
Is it detrimental to have a very short loop? My loop goes something like this... Rad -> 6 inch -> pump -> 4 inch -> CPU block -> 8 inch ->...
I have an Eheim 1250 pump, and as you probably know, it has a 5/8" tube fitting. I ordered it all from DangerDen, and got the 1/2" conversion,...
Does anyone play Silent Storm or the addon, Sentinels? I played SS for a while before I joined the military, and bought Sentinels while I was...
So I was shopping for a new videocard a few weeks ago, and stumbled across what I thought to be a really good deal on Newegg, a 512MB X1800XT for...
Ok guys, I've checked out the user reviews and done some research on what would be the best memory for the A8R32-MVP motherboard, with some pretty...
I was cutting a hole in the back panel of a case today, and was just finishing one side of the cut, when the reinforced wheel got stuck, and the...
Ok, so I know I'm not going crazy here... I wanted to take a look at the cathode throbber stuff, located originally here: cathode throbber. Are...
