Wow, that's pretty tiny! It's weird to thin of a case that's smaller than two 120mm fans side by side (or for that matter, only one 140mm with a...
Yeouch. Your "aging" system is better than the system I bought under two years ago. Thank goodness I'm two years behind in gaming ;-)
Ok, I shorted the green wire while it was plugged into the mobo. I learned 3 things: 1) The motherboard does not turn on 2) The CPU fan and...
See, I'm having a hard time understanding why in that case the PSU doesn't turn on the other motherboard, but in my case it does. The only...
I'm a fan of showing as much of your internals as possible. I'd vote design 1, but square off the hole instead of having the angle. Design 2...
I'm not sure what you mean. If you mean I should design it so that I can turn that stuff on before the computer comes on, well, that's what I was...
I'm not sure if your minimalist approach to a build log is working. Though it did get me to subscribe to see if you will add anything about your...
Ok, I've got everything 90% finalized, now all I have to do is start my job and get some money coming in so I can actually afford to build this...
Well I wasn't going to do that *every* time, just when I'm showing it off :) I have the 6 switches in my current computer, and unless I need to...
I dunno, it was just a crazy idea I had. I was envisioning a sort of airplane or rocket takeoff: flip a switch to turn on the PSU, then flip the...
Start with the last question first: I haven't bought it yet, but I'm looking at the Danger Den CPX-Pro which uses a 3 pin motherboard header. It...
Put some ears on that guy and it's a self-portrait of CHEAPS!
Hrm, I got that idea about shorting the green wire (PS_ON) from this thread (specifically posts #7 and #10). I was under the impression that...
I'm thinking about a new PC build and I want to have 2 switches to control the power/reset and to allow me to turn on the WC pump while the...
1) I don't know from personal experience, but according to the ATX v2.2 specs, you want 16 gauge wire for all but pin 11 which is 22. (18 gauge is...
You've got some really cool things going on in there. I love the way you route your cables and tubes... might have to steal some ideas for myself...
I've been working on a better version of the drawing (the one above didn't always take into account silly things like mounting hardware or plexi...
I added the other ones in there depending on your audience. Sometimes it matters what they look like, and obviously if you can't get them on they...
I read this just before I went to bed last night and, as an engineer myself, had trouble falling to sleep while thinking about it :) First you...
Looks pretty cool. And probably huge! What are the dimensions? What is it going to be made of? I'd love to get a look "under the hood"...
