Is there a Facebook group? Some 3d printers have decent support on there. Not sure if this is one of them...
Gridcoin too, you can get rewards from the SETI@home project (amongst others) with that one. http://gridcoin.us/
I mine a bit of Gridcoin myself. Essentially, you do BOINC work and it will give you coins based on how much work you do compared to other people...
I would go for EVGA E-Series G2 / P2 / T2 PSU Black/Red Braided Cable Premium Kit from CableMod...
Yep gone again, it was working earlier.
I got a letter too, but nothing else, no texts or phone calls.
I got offered the unlimited texts/calls and 4gb for £12, offered at £14 originally though, went to £12 after I said no to the first one. Going...
You could try the GPU in another PCI socket, just to rule out the clip being the cause. Do you have a different graphics card you could throw in...
Which OS are you using?
I've been listening to these two a lot recently. Trollfest are great fun. rMy0KPz8Vvo gzhx2Kifd5Q
I found that one in the same place you did.
I got a Beer Hawk selection for Fathers Day this year for my Dad. 30 bottles (or cans!) for £75. Admittedly a bit more expensive than going down...
Sounds good to me.
Definitely in, loved the originals :D
Could it be the particular PCI socket the GPU is mounted in?
I have had the Phanteks Enthoo Pro case for about 6 months now and its great. Addressing your points: I'm running SLI 760's at the moment...
:rock: I'm in :rock:
Yes, in the settings under Downloads (I think) there's an option called Steam Library Folders. Simply click that and you can add the folder from...
I have a pair with the standard blue lenses. Got them off eBay about a year ago for a shade over £100. Similar condition too, visibly used but no...
Wow, I hadn't realised it had become so bad. I started using it a few years ago and it was fine then. Thanks for the info :thumb:
