Place the url of the picture in between img tags: like this [img] And also make sure the pictures aren't larger then 640 pixels in width as...
This would maybe work for a few mms, but you will see the motor of the fan will get into the way, plus the fan blades are precisely designed so...
He mounted a 2x120mm Rad upfront.
Yes it will be fine to use to extend your fan wires.
Probably the frame isn't secured as tight to the LCD as it should be. Try and push it on further, but gently trying not to break the LCD.
I guess he's talking about your memory heatspreaders you use on the pictures showing the polished dvd drive. Nice work on the polishing, must have...
It's a sort of imitation leather I believe. Great mod Ediejo! :rock: , following this at GOT every single day :thumb: .
No it doesn't matter just make sure the red and yellow wires are in the right place but the ground wires are common, so there's no problem.
Search for "kalkammonsalpeter" Het is kunstmest van ASEF en het zit in een groene verpakking, http://gamekeeper.deds.nl/kas_suiker_rookbom.html...
You could probably find some at a store for speaker and amplifier parts. Or try and find an old amp or cd player, they often have these feet...
I don't think you were knocked down on the floor by 12 or 5 v from a molex :eyebrow: .
Amazing details on the pump :jawdrop: , fantastic mod.
Very nice project, good luck :thumb: .
Spray paint, just read the labels on the back of the can for info.
Wicked mod! You really know how to work your plexi :rock: .
Soldern them and put some heatshrink on.
Take a look at an autohardware store, they often have mesh which tuners use on their cars.
Realy neat mod. Love the pump :clap: and nice window.
Three words: Over the top!
Maybe so he can switch them separate from each other :thumb: .
