Ugh, I wish the big tech companies would all pull their heads in. This furore is Apples own doing. If they cut back on spouting off their...
Python is a nice language to get your hands dirty quickly. The thing to try and take on board while you are learning how to program is the why you...
Yeah I do update everytime I change sources.list. I imagined that the problem stemmed from grabbing testing branch packages that may not be in the...
Ok I've been playing around. I've gone back to the testing branch, and now have got php configured and working properly (such a simple...
Hi there, I've just installed Debian etch on an old machine I had lying around. A colleague of mine recommend that I be using the testing...
Thank you for all your help :) Seems as though because I had the bios set to look at the xp drive as 1st SATA drive, and the new to be linux...
Hi there, I've played with linux at school, and also mucked around with a few live cd's, and decided i want to have an install on my home pc. I...
I like it a lot. I didn't really use plugins in FF2, so I really notice some of the features which have become more comprehensive (the download...
Hi Guys, I was wondering if anyone knew of any music players I can run off my portable hard drive (which also has my music) as the computer...
Agreed that it is counter-intuitive. Especially because (well in my case) it was hidden off the screen, and you have to use the not overly obvious...
This might help you with your problem. Had the same problem with my motherboard which uses realtek audio chip on it. This seemed to fix it for...
I thought it was available tomorrow (tuesday for the USA, wednesday for NZ) through the windows update website where you download it manually, and...
Good to see you found the workshop interesting. I used it as a useful source of projects when I was teaching myself C# (had only used Java and...
I vote C#. As previously mentioned, syntactically similar to Java, and also C++. Also has memory management like Java. Nice free Express...
Hi there, I have recently upgraded my computer, and with that came a new motherboard. On the new motherboard it has an integrated Realtek HD...
You get that error if you try applying the update to a cracked exe. You will need to revert back to the originally installed exe to apply the update
Yeah I thought that a DMZ was total overkill for my purposes! Cheers for that, I think i'll just go for the non-standard port option and see how...
Hi there, I'm new around here to go easy :D With my first foray into 'real' Linux computing (writing small, and i mean small, batch scripts...
