For a low-volume, cheap solution, but separating the roles, I would like to build a cheap server which hosts the following VMs: - FreeNAS (direct...
Am looking for a good quality bluetooth (so I don't need to remember which device the dongle is plugged into) for use with Surface Pro, RaspPi 3,...
Calling all gurus? I want to build a pfsense router (2xNIC + Wifi). Small form factor. Preferably fanless. What components would you use? I was...
I have bought a number of EK products, this time around a got a warning notice. Saying in essence "Use EK cooling liquid... or else". Also, even...
Hello All, I have always used the on-line retailers (Scan, etc) when it comes to new builds, I have never tried eBay. It seems too daunting,...
I have recently got back into SC2. I never realised how deep and rewarding and almost infinitely re-playable (but hard) SC2 is. I was wondering...
Hello, How do you tell when a power supply is overloaded or close to max? Do you have to test it at the wall? Are cheap the testers...
Hello All, I am building a workstation for software development (need threads/memory); with a little bit of gaming. It will be a water cooled...
I have a good but dusty PSU I want to reuse for a new build. Am afraid of playing with real electricity/capacitors (12V is easy). What is the best...
I am struggling to find stock for a good waterblock, any suggestions? ATI 5870 (Asus EAH5870/2DIS/1GD5), which I am pretty sure is a reference...
Hello All, I need a build a coding development machine: multi-threaded, loads of ram, no gaming. While the "Core i7 2600K Unlocked Sandy...
Hello All, Some advice is needed. I was going to get an SSD -- only to be put off by the crazy price fluctuations. So I have gone back to...
