As the title says, does anyone have Call of Duty 2 (from steam) working on windows 10? And if so, does it run well? I did a quick google search...
I'm under no illusion that the budget is going to be VERY tight, possibly even impossible to do what I'm asking, so I am going to increase my...
I am currently buying in components for 2 APU builds for my 7 year old triplets to use for Minecraft (Win10 edition) Youtube and school use. I...
it was, as one says 'too good to be true' Edit - I finally went for the XFX XXX Hybrid 650watt, which going by the reviews, is a rebadged...
thanks for the recommendation. I'll take a look in the morning. edzieba mentioned to go for anything with an 80+ rating - Scan have some PSUs...
Thanks - one final question. Is there any reputable brands i should avoid? And any I should consider? I have been looking at the Cooler Master...
Sometime in the next 6 months I will be upgrading the the GPU from the 270x to something in the range of the 280/280x - 290/290x or Nvidia ??? -...
I need a new PSU for an upgrade to my current rig. The new build is going to be i5 4690K Gigabyte Z97 board - not decided which, AIO water...
GSMArena.com says the largest card usable in your handset is a 32GB card - try a 16GB if you have one and if there is still problems, try the...
further update - realized i had another cheapo PSU knocking about so switched it out as best as it would fit and it posts (couldn't check GPU as...
Thanks for the swift reply That's something I did do and yes I didn't get any post beeps but because there isn't one of them small speakers...
I am a little confused by what has happened to my kids computer. A few days ago the computer was working fine, but now I am getting no output...
Budget: I have £450 for my build/upgrade Main uses of intended build: Gaming (FPS - BF 2/3/4, Sim - FSX/Train Simulator 2015/ETS2, Racing...
Thanks for the reply - based on that i think I will have to change my mind and go with the Toshiba laptop unless i can find something else with...
i am looking for a new laptop for my wife with a maximum budget set by her of £330. I have found two different laptops which seem ok, but i...
is Crysis 2: Maximum Edition up for grabs? If so, could I possibly have it? edit - just noticed somebody asked for it on 18/9
So from that link you supplied, a comparison between the 270x and the gtx660 makes the 270x a better proposition in most games, which I would...
I suppose I don't really get buyers remorse - if a product is at a price I'm willing to pay then I pay it regardless of whether the price goes...
I was planning on ordering the new card this week. However if you're saying wait until the end of the month, I may be able to stretch to another...
Am I liable to have any issues with the PSU when putting a better GPU into my system? on top of the details in the sig, i have a total of four...
