I decided start using my watercooling again. I havent used it for over a year, but when playing games like crysis my graphics card is far too...
Hi, I bought a ultrsonic parking sensor kit but I cant seem to get it working. I tryed adjusting both pots with no effect, and the LED...
http://www.stm32circle.com/hom/index.php...
I noticed this 5" crt is only £5 http://www.ebuyer.com/product/105397 I am thinking how good it would be for hacking into a scope?
Thanks for reading. Im having some problems with my car system, which includes a 5" lcd, a hard disk and a 240v inverter. If found that if...
Its a psone lcd, I would like to connect it up to a composite (or svideo) input. this is the pinout (from here [img] I assume that...
Hi, as title I need a a 12v (10%) regulated supply from my car but not sure the best method to do it. It only needs to supply 200mA. I have...
Anyone used these before? or any other arm chip. I have ordered one and started to layout my pcb in eagle (just the chip, power and crystal so...
I have a sony CDX-CA650X cd player, and the built in tuner is broken (lose connection, sometimes works round corners). Ive tryed several ariels...
For a 3w LED, from 12v car battery, max current is 750mA. I am not sure if I need a 5v regulator (lm7805) before the 317t (in current...
This is for a 3w led torch. I can use 5x 1/3 AA batterys Or I have the option of a 5.5v 1F capacitor (or several in parelell, they seem a...
When I try to read this chip icprog shows everything as 0000, usually ic prog shows 3FFF for new chips, is it dead? Also it appears not to have...
3 wire EEPROM. Its A SOIC8 so I made a pcb to convert it to DIP8. Icprog supports it but the website doesnt have any details as to where it...
I would like to make a basic hot air soldering iron. Basicly metal tips are either too big, or dont have enough surface area (higher wattage might...
Another pc stopped working yesterday. Not sure if the mobo is dead, the leak seems to have shorted the leads on a few mosfets but I think they...
The battery in my nokia 7600 gets very hot if I leave the phone plugged into the adaptor for more than an hour or two.. So is 60c safe for a...
Lcd now works. this is my current code on the pic. The circuit is similar to this: [img] but DB7 is connected to RB7 (13) instead of RB3...
I tryed to make a 5v regulator circuit based ona lm317t so i could charge my phone from car from 12v socket. However when connected my phone...
I have a inforad gps speed camera detector.. which also supports nmea? for gps output and works with a laptop using gps software. It connects to...
I decided to convert my lcd back to svideo. I dont have the pcb with the connectors on so I need to find out where on the main pcb the svideo goes...
