Any recommendations?
Yeah there probably won't be much upgrading being done on this down the line, just really wanted to double check there weren't any better sites to...
Hi, Friend is asking for recommendations for a gaming rig for their son, budget is £800-£1000 and need everything, base unit, monitor, keyboard...
This look legit? Suppose with the postage it's only 25 cheaper than one on Amazon...
I take it that's used for 100 on eBay?
Hey guys. Long time some I last bought any pc parts. Don't even think crypto was a thing. So I just build my son a pc using some components....
Hi, I'm looking for a cheap KVM switch that will allow me to use two computers with two monitors. Reason being is that I work from a home...
Outstanding, thanks very much for the effort, much appreciated
Thanks very much for your replies guys, If you can be bothered could you do one tweaked with and without windows. I don't currently have it...
Hi guys, been a while since I built my sig rig so I'm out of touch, especially so when it comes to buying low to mid range. But my sister is...
Sorry should have mentioned that I have done so already and am still crashing at stock speeds
Hi Guys, As per the title, I'm looking for help diagnosing why my system keeps crashing. Not sure if its a graphics card issue, but that...
If I had the funds I'd replace my GPU which is by far the weak link in my build, then I'd replace my mobo as I hate the fact the temp sensors...
Thanks Guys, I actually bought it from Amazon back in August, so I'm going to approach them first, they've been superb up to now as far as...
Hmmmm, I don't think I have registered with them. How much will this matter? How long do these things take normally? I could really do without a...
As I', think,ing about writing this I think I already know the answer. I've been playing games with my GFX card since last Aug (gtx 460), it's...
I've got a funny one for you.... Man walks into the apple store and asks to buy a "top of the range" 27" iMac. "certainly sir, that'll be...
Ok thanks guys. I'm going to "tidy" these cards away into a dark corner and hopefully my boss will forget they ever existed! If so I'll pick...
Ok cheers, I'm trying to think though, I'm not sure my PSU has enough 6 pin connectors, you don't happen to know if it'll cut it do u? Or will...
Sorry should have been more informative in my question. I currently have the gtx 460 ssc in my sig rig. My employer just bought 4 gtx 560's...
