Hey, thanks for all your help. But, after a bit of tinkering throughout the day, I got the Titan to fit ( <3 Dremels). So now I'm getting 28c...
Whoops, I did indeed mean coolermaster. I got muddled up, reading so many names. My budget will be about 35 quid, and I'm really going for the...
Just looked up the Thermalright 212 Plus, I think? it's £16 on play, and seems to do EXACTLY what I want. As we all know, Sandy Bridge is very...
Alright, point taken with the SIlver Arrow, but it's out of my price range. HOWEVER;...
Nope, it's on default. I think. What IS default, anyway? It fluctuates like a mad man. I might do a RTC clear, see if I changed an obscure bios...
I've taken it off a couple of times, and I did mentioned I have used some arctic silver on it. It idles at ~36, which is better than my Fenrir did...
Alright, thanks man. Would be nice if anyone else with experience with this motherboard could comment on what they use for cooling.
And no, the cooler doesn't fit in any orientation. Alas :/
Yea, the RAM is definitely a problem, but as I have a Haf 922, the size isn't. Ho hum. What would you say about one of the Corsair watercoolers?...
Unfortunately, the cooler was bought in March, in anticipation for the i5 upgrade. And I used the cling-film spread out method. Always worked well...
Helloo good sirs, or lasses. Now, I have a conundrum- I recently bought an Asus P8z68-V motherboard (not the pro, but the layout's the same)...
It's Photoshop in tandem with the very useful but SO very poorly made InDesign. That's what chokes the system up.
8GB is definitely a consideration. My system chokes up with Photoshop and InDesign going on 4GB, so 8 would be the first thing to think about
Alack, no, I didn't use quidco, maainly as I've only really looked at in passing, and am not overly sure what it does. But thanks guys, lovely...
A bump if it wouldn't be too rude? My order has been dispatched, so it'd be interesting to know.
Hello all, I'm currently running an Asus P5QC motherboard, which has a P45 chipset, but as well as the base DDR2 support, it also has support for...
A nice bit of trigonometry shows that the diagonal of the Wii Remote is near exactly 6in. If that's the rumoured size for the screen, I could...
Ah, that makes sense. No fuses went. But I did have a surge protector, so maybe that helped. And it also wasn't too loud, probably just a minor...
Ah yes, Thank you so much much for all the input guys. I've submitted a ticket to OCZ, and as it's a £65 PSU, i'm pretty sure it has some good...
YUS! Success! Now I need to get onto OCZ to get a replacement power supply.... I got a random assortment off beeps, probably relating to missing...
