How much are you trying to increase it by? As mine will snap to discrete values. For example, my stock is 1012mv and entering anything up to...
Has this made much difference to your noise levels? I'm guessing its a bit louder under load, but no noticeable difference when idle. It's...
You could try using SteamMover. It can be used for any directories not just Steam games, and is basically junction points made easier.
Try installing them in smaller batches, rather than all in one go?
People only post with bad experiences, personally I have only ever had to use RMA once - it was with Scan - and I got a replacement 2500k and...
Have heard of people doing this with nvidia 8800s, considered doing it myself but decided to just buy a new graphics card in the end, as the card...
That is quite stunning, love it.
Sounds like you bagged yourself a great chip there, mine just doesnt want to know over 4.5ghz at similar voltages :(. Would be very interested to...
I found this during the beta, and renamed origin in steam so it showed me as playing BF3. But I've stopped using it now as I always forget to...
If you have a good after-market cpu cooler you should be able to run overclocks well over 1.3V. Mine is 4.5Ghz @1.36V and temps never go over 70c...
My 460 cyclone is @900mhz on 1.062V, but when trying lower voltages I have experienced the core just slowing down to 400mhz during gameplay and...
snooky32
Dan Brown - Deception Point
I'm guessing its related to http://www.penn-olson.com/2011/10/21/thailand-floods-hard-drive-supply/
Would have to say mass effect 2
Just got my key in the UK, at 14:40. Recheck your emails :p
I encountered this just a few days ago, it is now working after installing the xvid codec from here. If that doesnt work have u tried running...
In Order: ASUS V9520VS GeForce FX5200 XFX GeForce 6600GT 128Mb XFX GeForce 8800GTS 320Mb LeadTek GeForce 8800GTX 768Mb MSI GeForce GTX460...
[IMG] Sadface:(
I have one of those you linked, quite intersting for a while - I picked mine up for under £10 off ebay. I've also used one of these which are great
