I'm assuming you're talking about hd-dvd/bluray? Can't view it, sites down. anyway Yeah it'll be great. We'll all have to buy new equipment,...
This may no matter much because I don't know how accurate you expect your mock-ups to be, but.... If you bend cardboard with the channels...
robots.txt won't do anything for them. The problem, as stated in the bit tech article is that people subscribe to the site, leech all of the...
Buy regular rivets, and spray paint them before using them. then, any paint that rubs off when popping them, use a q-tip to paint them again....
Oven cleaner works great. I've used it to remove anodizing from RC car parts for years. In the US we general use Easy-Off heavy duty in the...
For a regular window I use tin snips, and get dead nuts straight lines with no ugly marks. Most use a dremel with cut off wheels. To avoid...
I used aquarium sealant when i did my son's aquarium. Glued a bunch of black river rocks together to make a cave sort of deal... Anyway, the...
I have red CCs in my case that WERE pinkish. I had a package of red split lom lying around, and 1 size fits perfectly over the tubes. It NOW...
Nah, there are a few things that you have to keep in mind. 1. For the next 11 months the technology that companies use is going to evolve, at...
BAH!!! The weather hasn 't broke here yet, so much of this is still on hold. I did get the fan grill, and I got the power supply painted, and...
Well, even if the first link is a "cheap" version, it's freakin 1/5th the price. Google for "spring loaded recessed handle" and watch how many...
Just mix it on a piece of cardboard or something. Preferable smooth, flat, and disposable. That way you can get it off of it, and on to what...
You'll be fine with that PSU. There's a lot of fanboyism, and what not going around against it. Maximum PC which some people feel is the...
I would be shocked at the very least if any type of encryption resulted in higher DVD sales. Personally I don't buy the "millions of people are...
MAN!! I'm glad I wasn't the only one thinking that.
I have no clue what he wrote, but the pics look good. Well, all except the piece that is dremeled "UNERAL" :wallbash: EDIT: Or is that some...
Nirvana, hands down in my opinion. I hate everything they did after nevermind, but that cd alone puts them at the top of the list. When Smells...
no doubt. however, I think george lucas needs to have his head removed for the new versions. The absolute worst part was the last scene in...
Thanks a bunch. Just knowing what it's specifically called helps a bunch. I might be able to find one locally now.
Hi all, Not sure if this is the right forum for this, but here goes........ I need to replace the power switch on a power supply. It's a 4...
