A "fiber inspection microscope" sound's very expensive :rolleyes:
I would go with cat 6A and stay away from FTP (shielded) as this might introduce noise in the cable unless all equipment connected is properly...
My what a long domain name. I know I would have trouble remembering it. Themeforest is damn good. Also nettuts and smashing magazine are good...
I have a password locked 2,5" drive. The drive would be usefull for some future project ;) Would issuing the "Secure Erase" ATA command, wiping...
Should you ever need it again you can find it online @ http://www.gigabyte.com/products/product-page.aspx?pid=3305#manual
Here is a quote from the manual.
I read an article not long ago about how even the top-end graphic cards don't use the full x16 lanes. But as soon as you begin to yank SATA 6Gb/s...
I can't wait until motherboards will have optical interconnection between the CPU, memory and other parts.
So you mean they have some kind of smart IC there? Well it didn't sound well in my head with just a plain old resistor letting one use any kind of...
Yeah thought so. 5V with a current limiting resistor on the motherboard.
1366 was never meant to surpass 1156. It's just that with 1366 you get more "x16" PCI-E lanes and bunch of other stuff that some people really...
Does any one know the voltage of typical motherboard's front panel "power on" header? I have this vague memory that most motherboards output 5V -...
I've been in contact with Intel and they claim they never heard of such a problems before. According to Gigabyte disabling C1E (among other power...
Once again no pictures :(
What made them decide to take the jump? Wouldn't this mean a total rewrite of the base code as it's based on monowall?
After doing a bit of research I found I'm not alone with a whining motherboard. It seems that it's quite common for Intel i-mobos to make whining...
I usually role my own modded Debian distro. But I have played around with FreeNAS sometime ago. It wasn't bad or anything but FreeBSD and my...
Too bad it doesn't have two ethernet ports. Would have make a nice mobo for a router.
Amazon might just have what your looking for. (http://www.amazon.co.uk/1-8m-DVI-TO-VGA-CABLE/dp/B000K5O1M8/ref=sr_1_1?ie=UTF8&qid=1293369392&sr=8-1)
