The first primer [img]
Today I got the parts for the cooling. This is again one step further to the "day of paint" [img] Again: THANK YOU TFC / The Feser Company...
To cut the side panaels I use my new saw station. [img] The cuts become perfectly straght. [img] The long side I cut freehand. From my...
Water in / out and the connector to the amplifier section. [img]
Today only a small update without a specification. [img]
Today grind the hole Case again. I think the "day of paint" comes closer. :D [img] [img] [img] [img] [img]
Another important detail are the case-feet. [img] To get a nice thickness, I need two 10mm parts. [img] Here just a short preview:...
To mark the other panel I use again the crepe tape. [img] Than two 5mm holes... [img] ... and a view seconds with the drill in a...
After a few days without an update... Today I cut the first "Side-flames" [img] [img] to be continued soon.... :D
To fix the USB stuff I use a plate, big enough to offer a sufficient "glue-area" [img] The opening is big enough to push the connector from...
The LED are only on the lower side. I use some superglue to hold the Plexi in Place. After the glue dry I also use some polyester resin on...
Maybe next jear. :naughty: And a short Update: This will be the "lighted push-button plate" behind the logo. Needless to say that I use...
Here is a final pic from the SlotIn [img] To hold the side panels in place I use some aluminium brackets. [img] First the holes (3x...
To find a good position for the DVD I mount the new Harware. At this point a big THANK YOU for the support MSI for the Mainboard(890GXM-G65) ,...
...and I wish i could find a way to live outside. :D Today only a small update. To hold the bord in place I use two bolts on bouth sides....
Today I spend again some time with the circuit board. Here are the potentiometer and the switch still on the board. [img] To get an new...
Today I start with the side panels. The are 10mm thick and a little bit bigger the I need them. [img] I start with the lower radius on the...
Again I get some Hardware. A Silent Pro M600 PS and 3 120mm Silent Fans. [img] For that stuff a big THANK YOU to COOLERMASTER Of course the...
This is one of the frames that hold the side panels. I only need the lower part. Therefore I start the Dremel... [img] [img] An other...
