nice review. I believe however the screws to hold the tempered side panels are there should you need to secure them while moving the case. You...
0.8mm thick aluminium for the outer panels? Isn't that flimsy?
no updates on this one?
Even deep pocketed governments cannot fight market forces in currency exchanges, which exceed 5.1 trillions dollars a day....
can an ambidextrous mouse be more comfortable than a specifically right handed one? I know it would depend on how you grip your mouse, but i'd be...
that was good laugh! it was bound to get political in the comments though.
I don't get it, aren't partners boards supposed to be cheaper than the FE?!
agreed with AlphaAngel. Motherboard makers are claiming their on board solution is as good as an entry level add in card. Would be great to test that.
I for one thought the combat was actually pretty damn good!
Me too, i don't get the negative reaction. I think it's awesome and convenient. If you have a better/faster/cheaper way of getting your stuff...
cable routing space was already tight behind the mobo tray on the FT02, is this even worse? and why would they do that knowing it was a weakness...
been enjoying SoM since release, fantastic game. I do find it a tad too easy (so far), which can sometimes ruin the nemesis concept since orcs...
What are you planning to do with it? maybe a little write up telling us about your experience with the board?;)
I only made one point, not sure what the other points you're disagreeing with are.. Who mentioned strain on the mobo? I was discussing noise...
Certainly not quieter. Even having the same fans at the same rpm in both an aio and air cooler, you'll still have the pump noise and vibration...
i thought the whole point of tactile feedback (eg: MX browns) was so that you know when a key is activated and you don't need to bottom out....
those numbers:) .. those colours:(
Nobody is saying it's a safe investment. All some of us are saying is that Bitcoins derive their value exactly the same way other assets derive...
Replace gold with bitcoins..
Hope you guys will do a pc comparison when it's released.
