[IMG] Sent from my Nexus 6P using Tapatalk
Scary thing is the msi cards are designed to run at 95 degrees with full speed on the fans, and the fans don't come on at all until the temps...
So, in answer to my own question, it was a no, got the cards in this morning and it was like a nuclear reactor about to blow. So I have rebuilt...
So what would you suggest regarding the h75, have it as push pull but facing out of the case ??? The only reason I'm going with the two r9s is one...
I've only ever had good times with my other crossfire setups, why would this be any different. ??? Sent from my Nexus 6P using Tapatalk
Hello I've just built my skylake gaming PC, The specs are I5 6600k Gigabyte Z170X gaming 7 16gb corsair vengeance 120gb ssd m3 3tb hard drive...
Cheers for the replies. Appreciate it. Many thanks. Sent from my Nexus 6P using Tapatalk
Just looked again and I think the rubber for the grommets would need to come out. Or just cut the angled section out and it will fit regardless....
The tray is flat and it angles at the start of the rubber grommets. The angle isn't massive which is why I think the eatx board will fit. Sent...
I've got this case, you could fit a eatx board in but you would loose the angled rubber grommets but there's still plenty of space by the hard...
Hello Just built a skylake gaming PC Just wondered if this would be okay to run R9 390 in crossfire Gigabyte gaming 7 z170x DDR4 16gb corsair...
Hello, Just built my son a new itx pc for his room, I used an old corsair psu I had as it's only seen about 5 hours use in the years I've...
