Yeah, brand new one. Guess I just got unlucky on that one.
Okay guys, just for a conclusion to this. Took the stuff down to a local pc store. Had it tested for a tenner. Turneed out it was the PSU, so I...
I don't have another gpu to test with unfortunately. I've tried removing both the gpu and ram and I don't get any beeps still. Maybe my speakers...
This is a bit of a continuation of this thread http://forums.bit-tech.net/showthread.php?t=190054 To give the lowdown on everything, essentially...
Well, I just got back the RMA report that no fault was found. :/ I'm trying to see if they did or can test the two together but I dunno :/ Have no...
Yeah, thats what its looking like im gonna have to do. Happen to stumble on newegg reviews of the board and quite a few others had similar...
dont hav any other card to test. Tried reseating the mobo and nothing. Tried reomving the metal retention clip that hold down the graphics card to...
no luck :/
Fliped around the speaker cable. Still nothing. Blew on the pci-e slot and gold pins to clear any dust or w/e still nothing. This is really...
Yes, dvi is in graphics card. From some googling, it seems that this has happened to others. I'll try the system with out the graphics card and if...
Checked the 4 pin connector and its in. I cleared the cmos I believe (just move the jumper for a few seconds then move it back, or do I have to...
So I assembled my first pc, but when I go to turn it on, I can see the cpu fans, case fans etc whirring, I can see a little blue light on my mobo...
Thanks for your help guys!
Considering its already sub based, I cant see why they need ads in too. Maybe they're expecting a low user base? Put me off it for sure.
Quick question. I have 2x2gb ddr3 sticks. In the user guide for the mobo it states "In Dual-Channel mode, make sure that you install memory...
Say Angels and Demons the other. Film was alright but it was very plot heavy, I get the feelingt Id have to watch it several times to fully...
Looking great so far! keep it up
Custom pc 83
Yeah, I'd just get it replaced if its in warranty. If it isn't, then is the time to start messing around with the myriad of solutions there are...
Gotta say, I had no idea you could make your own pcb. great guide.
