:wallbash::wallbash:Sorry to bump guys but I really need help with this. Surely somebody knows how to fix it? Thanks once again :)
Tried that to no avail!
Hey guys. Since this evening, when I sign into Windows Live Messenger I get the following window pop up. 'Windows Live Communications...
Hey thanks for your reply. What are NIC's and GNICS? Sorry I'm thick haha.
Hey there guys. You may remember I posted a thread a few months back about an i7 build I was looking to get, but the thread died without...
Thank you.
Hey guys. For using an i7 system, what would be the best brand, type, mhz and amount (i.e - 2x6 or 4x2GB) to go for? All I know is I want...
Yeah, I am definitely going to go for a hefty overclock, so the Rampage is the one for me in terms of features. With the watercooling. Is it...
As I said before the Lian Li PC-P8- Armorsuit is a fantastic case! & Is very watercooling friendly. If you have the budget for it then I would...
Yeah the Rampage Extreme II Mobo comes with some kind of X-Fi Sound? So is the Asus Xonar DX2 the best? I would have assumed Essence was...
Yeah, Well i have neighbours either side, but they are used to me and my houseparties and blaring music, and if they don't like it then b***ocks...
Any luck with the quotes yet guys? I do appreciate it :) Also, these new 1.5TB and 2TB Samsung Spinpoints. Are they actually fact or still just...
Ah good. Thanks for that!
Bagman I take it the Koolance is i7 compatible or designed?
The Lian-Li PC-P80 case is great for air-cooling and it's fulltower - MASSIVE! Plenty of room for even the biggest water-cool's!
Wow. Haha. I do appreciate your advice on the HDD's. but I think I'm just going to stick with my initial choices! But thanks nonetheless & a...
Haha, exactly! £10 is nothing compared to what you're getting additionally! Thanks for finding it BTW! :)
I will be getting one of those then! :)
Hmmm, it's nice enough, but give me the black Luxeed anyday!
