hey guys just wandering if someone can clarify something about this article. it talks about open sourc eversions whs, but only lists individual...
i would love to see some new small but super fast components that can built into a killer gaming pc small enough to transport around regularily.
yeah ive never had them connected up at the same time and to make sure there wasnt a conflict deleted the downstairs printer so only the usb one...
hi guys, not at home at mo so going from memory, but i did unistall and reinstall drivers and it only appears once in the printers list. its a...
used to be able to print fine on my desktop ( running windows 7) but then all of a sudden i can not, i always am getting errors that are...
Hi there i can also confirm that the CM 690 II Advanced iis a brilliant case. just recently built an i5 machine in one for a family member and am...
yes the mac book pro can be upgraded because it was designed to be. it uses standard ram modules and hard rives that you can swap out and in. the...
erm, doesnt the macbook air have the storage chips soldered directly onto the motherboard, not on pcb's that are still seperate jsut smaller ?
cheers for all the replies, might just get a homeplug or try and find a mega long cable and pull out the drill :D as for the hippoz, i do have...
hi guys sorry for the late reply, the fenrir is a really good cooler i jsut want something abit more quiet and "efficient?". was also thinking of...
Hi guys, ive just bought myself a zyXEL GS-1524 network switch so that i can connect the 3 computers, a printer, xbox 360 and ps3 (i have...
i have nto used this one in particular but i can highly recommend the icy box external enclosure that i recently bought. it takes any 2.5 inch or...
http://www.scan.co.uk/Products/XSPC-X2O-750-Dual-Complete-WaterCooling-Kit-for-AMD-and-Intel-CPUs was thinking of getting one to put on my i7...
cheers for such a good detailed response, ill shell out the extra £20 just to get the 3.5 inch to 2.5 inch adapters if thats what it comes with....
hi guys just asking if this is a good case? am going to be putting an i5 760 and ati hd5770 into it. can it take a corsair h50 cooler? also...
what was tis so called Demot Thread?? bit before my bit-tech time i think :P
yeah i have thought about overclocking the 920... posted a thread bout it in the hardware section as i have no clue as to how to go about doing so
hey guys, never overclocked anyting before and just want to get a little extra out of what ive got, just to see if ican.. specs are: i7 920...
have started doign the intel progress through processors thing and its given me the distributed computing bug and so i want to start...
lies
