Any exist?
How would you go about adding a rust effect to plexi?
I have some speaker bars I'd like to use for my TVputer project.. but I don't want the extra plug, for the sound input or power. What would...
Do they exist? I need something as small as possible and one that is very powerful.
Is this possible? Has anybody done it? It would be great for my TV computer (powered by a 15-inch LCD). If this is possible, I'm a complete...
I want to build myself a mini-PC based off of battery power, like an OQO. I need a small motherboard that can a) handle XP, b) takes up as little...
I'm building a plexi case that I want to paint a nice black. I want to make it so that, when the character LCD is off, it looks like nothing is...
I just refurnished my room with beautiful wood pieces. I bought a small 480i TV, some Micro-ATX and cheap computer parts (Sempron 2300+, 256 MB...
Will an Antec Aria overheat with one of those babies in it?
My inspiration right now is G-Gnome's WMD project. I like a lot of its aspect (namely the screws all over, the panel for the timer), yet I want to...
Where can I find a long LCD? I want one that is about the height (or at least 50% of the height) of an ATX mid-tower.
Hello, I have a great idea (inspired by a few mods here) to build an aluminum rectangle for a case (want it to be in the shape of a stereo...
Which one trumps all? I'm stuck between Crystalfontz and Matrix Orbital and which one of theirs to buy. I don't want to spend more than $70.
My PVR will be taking up the one PCI slot on the Mini-ITX mobo I plan to purchase for my HTPC-in-ammo-box project. Any suggestions as to how I...
Anything I should take into consideration?
I was reading the "Ammo PC" by ZapWizard thread over, what a project log. :D But I found a discussion going on in that thread that interested me....
I want to add my name (or something else) to some faceplates for CD-ROM drives that I am making out of aluminum. Where can I have this done, and...
I tried using the calculator, but I can't find the right numbers in here to calculate. I need to know what resistors I should buy for the...
Hello, I opted out of buying a Dremel and decided to buy a $120.00 router. I want to do some aluminum cutting for my first project (a big...
Hello, My ammo box project (Ammo meets Orac) will begin soon (promise). But I need a heads-up of ideas for my next project, which I am very...
